Question about GE Washing Machines
I purchased a GE washer back in 3/31/07. The service tech was called SEVERAL times for overflowing. The washer is a Model WhDSR209G2WW Serial #FM1311606G. I do not want the machine. Can I trade it in a get a credit. I am very unsatisified! I stated while It was under warantee that I am fed up wiht the machine with no results. Paul Schuber 338 Latham Road Mineola NY 11501 516 294 9478
I am having the same problem. I found junk in the tub cleaned it out and it still seems to not shutoff. I haven't gotten any further. But I am currently working on it. I am in the process of taking out the bucket to see if there is **** in there clogging it more.
Posted on May 25, 2008
  • 1,028 Answers
If it's a top load remove front panel and ck small hose on left side on lower side of tub be sure it is clean and not blocked if it is not suspect fill level switch or fill valve ..trash will sometimes get past valve screen and into valve not allowing it to shut off either problem can be intermittant
Posted on May 21, 2008
Will not finish cycle without restarting
Hello. When looking up your unit for the service manual, I found that it might be subject to a service flash--potential fire hazard. You will need your complete model and serial number. Call GE (877) 275-6640, and find out if your washer is in the list. There is a condensation problem in the door which can cause moisture to drip down onto the control board causing a short circuit. There needs to be a cover over a fuse on the board. If your unit has a green dot next to the sticker which has the model/serial number on it, it's already been modified. If not, then GE will send a parts kit and you will have to get a tech to install it.
Oct 13, 2015 | GE 24 in. Monogram ZBD6880KSS Stainless...
Model gfwn1100 front load washer
It shuts down because of time out, is the water turned on, sounds stupid but it has happened several times, I go on a service call just to turn the water on to the machine.
Feb 03, 2014 | GE Washing Machines
Adora washer has given several years of trouble-free service. Lately, water overflows the drain standpipe and flows on to the floor. Machine washes, spins and rinses just fine - the overflowing is the only...
  1. If the drain water is overflowing the standpipe then you have a problem with the house drain not the washer.You need to clean out the house drain or call aplumber to do it for you.
Jun 17, 2011 | GE WSXH208A Front Load Washer
We are having the F1 problem everyone else seems to be having. However there is NO serial number tag in our washing machine. We purchased it at Lowe's; I have called them and they don't keep serial...
As a service tech I ran into this several times.I do not know what the law is but I know as a service tech we were not allowed to perform any warranty work on any unit that did not have a valid serial number.In all my cases the customer went back to where they purchased the units and demanded that they make it right ,and in 90% of the cases they exchanged the units (but not without some dissagrement) obviously you need to work this out this is not a cheap repair
Sep 17, 2010 | Whirlpool WTW6400SW Cabrio Washer
Ge whdsr209g2ww knob contrel is not line up
The switch that the knob is connected to may have come loose behind the console. Unplug before you remove the back of the console.
Dec 24, 2009 | GE WDSR2080D Top Load Washer
Washing machine does NOT stop filling w/ water!
If the m/c keeps filling, where is the water going ??? if the m/c doesnt reach the required water level it will not start, check the drain hose at the back, make sure its at least 24" above floor level, if it lower then it will just empty as quick as you fill it on gravity.
Nov 19, 2009 | GE Washing Machines
Washer leaks during spin and rinse cycles...hoses are firmly attached at the back. no water at back of machine, just the front. it is an older model 7 cycle GE. no model # thanks
I still would check your water pump under the machine. you would need to take your washer cabinet off to see where the water is coming from. If you don't know how to take the machine apart i would call a service tech and let him figure it out as it could be several different things.
Oct 31, 2009 | Washing Machines
Model: WBVH5200J2WW
call for service it is cover under warranty... all front loaders have a door gasket and all of them get holes in them...
Sep 02, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washer will not drain has a code F72
Good you ran diagnostics, F 72 shows at c7 when the basket settles after draining the water out. F 72 is a basket re- engagement failure, does your machine go off balance easy? I need to know is the machine was purchased at Sears and the serial number. If so I will get a special phone number for recalls. I hope it is a Sears machine, we see if the hot line can schedule a tech to service the machine. What the recall line will need after confirmation of a Sears purchase is you name and phone number plus model and serial number of machine. Now they will also need the part numbers to order. When these parts are ordered they will ups them to you which at that point you call back so recall can get a tech out to repair the cabrio.
motor control unit part # W10201186
Washplate part # W10077050
Recall number for Sears machines only 1-800-659-7026
I appreciate the chance to help you today, I had a machine like yours today and yesterday with same issue:)
Aug 11, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Purchased ge counter top microwave feb.2 from best buy it has quit heating, why?
Your oven should come with a 1yr. warranty. Try calling the toll-free number below. They should help resolve your service issue. Have your model, serial no., and proof of purchase handy when you call.
May 23, 2008 | GE Microwave Ovens
Washing Machines Logo
301 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
