Question about Gateway Computers & Internet
My internal speakers have sound when headphones are used but no sound when they are used without headphones
    Problem Solver:
  • 29 Answers
My frnd the internal speaker will have sound by default it comes from dos...When it comes for headphones or speakers u have to install the sound drivers which comes from pc.....install it it will work...
Posted on Jun 06, 2008
When plugging in a wireless headphone in the audio output the tv's speakers shut down.How can I stop this
The speaker cutout feature whenever the headphone jack is connected is a hard-wired feature of the headphone connector, and cannot normally be bypassed without further electronic circuitry and the associated surgery to install a custom modification in the TV. In order to keep the TV speakers on while using the sound elsewhere, you will have to take the audio output from the IR Audio port, if there is one.
Apr 02, 2015 | Olevia LT37HVS 37 in. LCD HDTV
How to fix my acer aspire 5740G model lap top sound distortion, When it with Speaker connection its clear, Without speaker its more distorted, any one can give solution?
This is due to the internal speakers which might need replacing, it sounds better with external speakers because they are plugged into the headphone socket which shows the internal speakers are damaged, get them checked out.
Jun 08, 2014 | Acer Aspire Computers & Internet
The sound has stopped working on our GeoSafari LAPTOP No. 8545. Help!
Hi Lisa,
What operating system are you using?
Check that sound is enabled in both the operating system and BIOS.
Check that you have the volume turned up.
If you have an external set of speakers, try plugging them in and see if you get sound. If the external speakers use a power supply, make sure you have the speakers powered and turned on. Computer speakers almost always require power to run the internal amplifier. Computers sound output is so low that regular speakers can not be used. Also, if you have a set of headphones from an iPod or similar device try the headphones. Headphones are sensitive enough to work without power.
Aug 06, 2012 | Computers & Internet
No sound from internal speaker, but I can hear using headset. The problem heppened with Laptop HP 620.
This is a possible damage on the internal speakers or a connection fault at the headphone jack connector. you might need to open the laptop to check and confirm on the connectors.
Jul 25, 2011 | HP Computers & Internet
Why does my I-mac not recognise both internal and external speakers in the sound preferences, so that I can switch between the two without having to unplug the external speakers from the headphone output.
There is an internal switch inside the actual 3.5 mm headphone/speaker jack. When you have either headphones or speakers plugged in, it automatically switches to external. FYI: Macs are also notorious for getting 'stuck' in this mode (external) and I've had to walk numerous people through the steps to correct this. My Macs are definitely not excluded :) I hope this helps.
Jan 08, 2010 | Apple MacBook Pro Laptop Computer with...
My last Reciever, I had wireless speakers that worked by plugging into the headphone jack. When the wireless transmiter was plugged into the headphone jack I still had sound coming out of the main...
Your system is designed to interrupt the signal flow once headphones are attached. It can not be changed without internal modifications. There is no control to do this.
Dan
May 12, 2009 | Yamaha HTR-5730 Receiver
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
Sony VAIO VGN-CR23G Sound
i have sony vaio VGN-CR23G. i formatted this xp sp2now the sound driver is not installed on my machine. no audio output m getting........what to do..??
Sep 20, 2008 | Sony VAIO VGN-N130G/W Notebook
Headphones
If you can elaborate on the issue, then that would be great!!
Anyhow, let me assist you in this regard.
There will be built-in speakers in all HP notebooks. You can hear Music and songs through them without headphones.
If there is no sound from the Internal speakers, and if you are able to hear sound from the headphones and external speakers, then the Internal speakers gone bad.
If that is the case, then you need to contact HP to replace the speakers under warranty. If not, service center.
If you can reply with the exact issue, then I can explain in better way according to the issue.
Apr 04, 2008 | HP Compaq Presario C500t Notebook
Computers & Internet Logo
246 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
