Question about Audiovox AVT1498 TV
TV power goes off after 2 minutes 45 seconds
Recently purchased a 1994 conversion van with this 12v color TV. Except for a bright line across the very top of the screen, it was working fine. Then one day it would not come on at all. Fuse was blown in factory 12v 2A power cord plug. Replaced fuse, blew again. Took plug apart and found that vibration had worn a hole in wire insulation and the hot wire touched the ground clip and melted the insides of the plug. Replaced with identical new Radio Shack 12v 2A power cord. Now TV works fine for 2 minutes and 45 seconds and then it shuts itself off (yes, 2 minutes and 45 seconds exactly). Power supply heating up? Voltage regulator fry when 12v plug shorted? If so, where could I get replacement parts? I could replace the TV with one from eBay, but would rather try to salvage this one and save the money for gas. Any suggestions appreciated.
    Brigadier General:
  • 6,966 Answers
The short in the plug would not have caused any problem internally to the AudioVox. I would suspect another problem (electronic). Your description of the bright line at the very top of the screen is indicative of a possible vertical capacitor about to fail. Having said that, it is also probable that the vertical IC could be affected and thus the unit goes into shutting down to prevent further damage.
If you are comfortable and familiar working with electronic circuitry and components, use of a DVM and a soldering iron, then a DIY would be relatively easy. Access to a service manual or at the very least a schematic diagram with voltage readings would be of great help narrowing the defective components.
Should you venture into doing it yourself, pls post back, otherwise perhaps you would be better off seeking the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 20, 2008
  • 3,037 Answers
Check the capacitors and the voltage regulator. The parts should be able to be purchased from an electronics store like Radio Shack.
Let me know if you have any further questions or if you need help knowing how to do this,
good luck
  • Benjamin Patri
    Benjamin Patri May 24, 2008
    Were you able to fix this, if so then please give me some feedback by rating my solution. If you need any more help, I would be glad to assist you, just ask.
    thanks and Have a Great Day!
    Genius:
  • 2,035 Answers
The power from the outlet is high check the voltage at the connections this may short in the wiring of the van please check all the connections and for parts:
A web site with repair advice for video monitors:
"Service Engineers Forum"
http://www.e-repair.co.uk/index.htm
A web site for a parts and component supplier in Kentucky:
http://www.radioelectronics.com/
Radio-Electronic Equipment Co, Inc.
480 Skain Ave.
PO Box 1209
Lexington, KY 40508
+1 859/255-6661PS Dont forget a fixya rating!
good luck..................
    Sergeant:
  • 406 Answers
There is a contact loose verify with qualified technician for physical setup being tested.
1994 G20 conversion van. 6 cylinder. Engine running in park. When I apply brake. Engine quits then van will not restart.
Check vacuum lines.
There is a large one on the power brake booster that goes to the back on the fuel system. Make sure you have vacuum before you try anything else.
A vacuum leak will cause you to stall out.
Dec 28, 2016 | 1994 Chevrolet G20
How much power does my SW214-SCC need?
On the details it says :
380 TV lines Minimum Illumination 1.5Lux Output Standard CCIR/EIA (PAL/NTSC) standard video signal Lens Size and Visual Angle 6.0mm 45 Automatic Shutter 1/60 second - 1/15000 second Supply Voltage/Consumed Power 8-12V 120mW
so any AC adopter from about 10 volt will do.
Apr 18, 2015 | Home Security
Noticeable line through screen picture sony KDL-40V3000
TRY USING THE COLOR CONVERSION OPTION ,,ITLL FIX THE COLOR
Mar 07, 2009 | Sony BRAVIA KDL-40V3000 Television
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
WD-52525 screen is jumping all around with wavy horizontal lines etc.
Good Day;
Keep talking to the factory, it is their product. Best Buy won't replace unless it is deemed not repairable and/or terms of the contract. You purchased the extra warranty because you most have felt that the TV might break down. Well, it did, now use the contract to repair your TV.
Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Power turns off automatically
happened with my 2002 42" model. they say the convergence circuit.
Mar 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Color problems at top and bottom of screen
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.eserviceinfo.com/
http://www.digitalhome.ca/forum/search.php
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 17, 2006 | Hitachi 42V715 Rear Projection Television
Audiovox AVT1498 TV Logo
132 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
