Question about Kenmore 22422 Top Load Washer
Kenmore 80 series washer 4yrs old
My washer will not spin. It makes a clinky noise but nothing happens.
  • bradeja May 20, 2008
    My Kenmore Model 20722990 does the same thing. Wash cycle works great, but spin cycle doesn't work. Just a loud clanking/grinding noise (not anything to do with off balance) and doesn't spin at all. I took the agitator off, and there's no sign of worn teeth on gears, etc. Any help would be much appreciated!
  • rrich929 Oct 25, 2008
    how do you change this part?
My husband took everything apart! The problem for us was a $16.00 coupler? I think that's what he swore ha ha, anyways, it was broken in two, and now my washer works great! I hope this helps you guys...Brenda
Posted on May 24, 2008
How'd ya take the agitator off is what I'm trying to figure out
  • 1,028 Answers
Suspect gearcase problem or broken brake release on bottom side of basket drive
Posted on May 21, 2008
My washer suddenly started making a grinding noise while spinning.
You did all you could do it sounds like somebody had something in a pocket an it fell out got between the drum of the washer an housing an is gonna make noise for a long time till you replace the washer sorry it happens all the time
Nov 16, 2015 | Washing Machines
Kenmore washer will fill and that it when it goes to start spinning it makes a weird noise
Sounds like the controller behind he knob is shot. May be cheaper to get a new one or look for a new used one on craigslist. If you google the model number and addparts list it should bring up a link to the sears parts list. Youcan then gogle the part # for the controller module and see what it costs.
Dec 02, 2013 | Kenmore 22422 Top Load Washer
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Chugging like noise during certain cycles
your clutch need to be replaced as does the tub shaft bearings i;m sorry this is not a do-it-yourself job, try to make a deal to trade in your washer
Apr 22, 2009 | GE Washing Machines
Whirlpool top load washer LSQ9610LG0 wont spin but makes noise
HI thanks for your question. the part that failed is called the motor coupling. it s located on the motor and the transmission. if you need help to replace come on back. but that's the part you need to change. thanks
Oct 14, 2008 | Whirlpool LSQ9610L Top Load Washer
Washer making buzzing sound during spin cycle,then stopped during wash still has water in tge clothes,buttons light up as if going to work but nothing happens jusy buzzing noise
If I understand correctly, the washer made a sound in the spin cycle but didn't actually spin the clothes dry?
If so you may have something in the pump that is not allowing it to pump out. Disassemble the pump and make sure it is clear of any debris.
Jul 21, 2008 | Frigidaire Washing Machines
Washer tub doesn't spin freely
Belt may need to be replaced. Can be worn to the point where it is too loose.
Apr 07, 2008 | Washing Machines
Kenmore Super Capacity Washing Machine
If your washer is the one you have chosen a Whirlpool built kenmore unit than your washer doesnt have any bearing that fail, It could be the spin tube mounting block becoming stripped ( most common) or a clutch or brakes not releasing issue (not likely). Also make sure the machine is agitating it may just be filling with water and draining and making motor noises. In this case the motor coupling has broken. both the block and coupling are inexpensive parts and easy to install.
Jan 14, 2008 | Kenmore 3.2 cu. ft. Top Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
281 people viewed this question
Sal De
 Brian Main
Brian Main
