Question about JVC AV-27530 27" TV
Video input selection remains displayed - can't get rid of it
How do I rid my screen of this unwanted display??
1. My remote is not available
2. Somehow the shorthand for the video input port shows up in upper lefthand corner of screen (like V-1 for video 1 or V-3 for video 3) when I move my VCR RCA jacks to that port and select it using front panel buttons. After changing volume to exit front panel menu mode all displayed items disappear momentarily and then the shorthand V-1 or whatever comes on.
3. I've even shut it off and unplugged it, but when I plug it back in and turn power on the V-1 still shows up.
  • tennant27 Feb 27, 2009
    same thing for me
The solution to your remote problem is to go to wal-mart and when you go through the check out lane there is usually some last minute items. there is a silver remote that is usually hanging in those aisles and that has been the only one I have found that works.
Posted on Mar 07, 2009
Dell 2407 Can't get rid of "No S-video input signal" message on screen. How do I get rid of this?
Your S-Video connection is referring to a round plug for a TV input signal. Most computers will not have this connection unless you have a TV based video card. If your using a TV 'monitor' as your computer's video device, their will either be a button on the monitor or your remote to allow you to choose the input signal. If you are using a VGA or HDMI or DVI cable as the connector between the two devices, most likely, the light is referring to one of these, as its video source. You will need to match the cable & monitor source detected to get a usable picture output.
Good luck.
Toby.
Sep 28, 2015 | Dell Computers & Internet
ON SCREEN HAD POWER ONLY V8.02.8
FOLLOW this instruction and fix it. God bless you
Connect the component video, HDMI1 or AV1 cable from the component device (such a DVD player) to the appropriate input port on the TV. This port may say "Video IN" on the back of the TV. Ensure that the cable is connected securely at both ends.
· 2
Use the remote control's device button(s) to access the menu and select the input through the menu that matches the type of cable input connected to the back of the TV. For example, if you connect the cable to the HDMI1 input port on the back of the TV, selecting anything but the HDMI1 option with the remote control may cause the "No Display" message to appear, which usually means that the TV is not receiving a signal at the connection input you have selected.
· 3 Turn the power on to the component you want to view. If the power was off, turning it on will activate the display and replace the "No Display" message.
· 4
Test any other connected components at their selected inputs to see that the TV is receiving the video signal properly from those sources.
· 5
Check with your cable or satellite provider if their set-top box is the source of the "No Display" message and is powered on, to see if the problem is caused by a disruption in their service. If using an antenna, adjust the antenna and re-scan for available channels.
Jul 20, 2013 | LG 55LE5400 55IN LED HDTV 1080P 120HZ 4...
I have a grey band on top of our screen indication HDMI1. How can I get rid of it. help!!!
If you press the INPUT button on the TV remote you switch to your various inputs, you have HDMI 1 selected. The info banner will display each time you switch channels or inputs. Press the DISPLAY button on the TV remote. Press again if info does not go away after 10 secs. Check your INITIAL SETTINGS on the TV to fine tune this kind of option.
Mar 13, 2011 | Sony BRAVIA KDL52XBR2 Television
I am useing this yv to play video games on but the video 1- video 2 or component setting are always on the screen and i would like to know how to remove them thanks
Use ur tv remote.Press the display button on the remote should get rid of the Video input 1 or 2 reminder display on the tv screen.
Feb 03, 2011 | Sanyo DS24425 24" TV
How to enable the input of lcd
hi,
u can sellect input by following setup
1. Press INPUT. on remote
(A list of selectable sources appears).
2. Press INPUT again to select the input
source.
( An image from the selected source automatically
displays).
Each time INPUT is pressed, the input source
toggles.
If the image does not come in clearly from the external
equipment connected to INPUT 1 or 2, you may need
to change the input signal type setting on the "Input
Select" menu.
1. Press MENU to display the MENU screen,
and then press c/d button (on remote) to select "Option".
2.Press a/b button (on remote) to select "Input Select", and then
press ENTER.
3.Press a/b button (on remote) to select the signal type you
want to set, and then press ENTER.
4.Press MENU to exit.
just try these. need further help feel free to contact.
ok.
Dec 20, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Our son pushed some buttons, and now we cannot get rid of the square in the upper right corner that says "video 2". HELP!
Video-2 is on-screen display. Press Display/ info button on tv remote, on-screen display will disappear.
Please note that only Sony tv remote will work to cancel on-screen display.
Thanks.
Jul 28, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Video input indicator remains on screen
Press the "DISPLAY" button on the remote control. This will cycle through the display choices and then turn it off.
Apr 04, 2010 | Sony FD Trinitron WEGA KV-24FS100 24" TV
I have a Sony Trinaton XBR about 6 years old. Works great. Have Comcast cable and they recently installed a new cable box. Now I get all cable channels on "Video 6 - DVD" rather than "Video 7 -Cable Box"....
I was awaiting your response in chat session but could not get any thing.
Please hook cable box in Video input-7 instead of Video input-6 in TV and select Video input-7 with remote on TV.
Regarding continues on-screen display of video-6, press Display button on TV remote once, on-screen display will disappear.
Thanks.
Jul 12, 2009 | Sony Televison & Video
Video Source Text remains in upper left corner of screen (video 1, video 2, etc)
If you have the original remote control, press display to get rid of it.
Hope it works.
Mar 10, 2008 | Sony KP-46WT500 46" Rear Projection...
Wording permanently on screen
I have had this problem all along with my Sony, not being able to figure out how to get rid of the Video 1 setting! I read this posting from Kessa a few minutes ago, and I tried hitting TV and Display - I couldn't find Display - it was because I had picked up the wrong remote! I had the Comcast remote instead, and when I couldn't find Display, I pressed Info - and it disappeared! Then I realized I had the wrong remote. I tried this process again using the correct Sony remove - I hit TV and then Display and it did work! Yay! thank you so much.
Oct 30, 2006 | Sony FD Trinitron WEGA KV-36HS420 36" TV
JVC AV-27530 27" TV Logo
302 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
