Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
Won't **** up water
My son used the machine one time before I got to use it and I am not sure he vacumned before using it and now it doesn't **** up the water once you spray it on the carpet. Is there anything I can do for it without taking it in for service?
I couldn't find a model # but this is what it says on the front of the machine
  • Susanism Jun 14, 2008
    Doesn't have suction from the floor. Feel strong suction from the top where it feeds into the clear bucket.
    President:
  • 1,673 Answers
Check the filter that is on the end of the tank lid to make sure it isn't clogged. Check to make sure that the seal o gasket, black, ovule shapped is on the top of the clear window. It has to seal the tank edge to the window. Is the knob on the left side in the hose position or floor?
Posted on May 20, 2008
My Bissell proheat2x leaks water from bottom of machine, if you have the water tank full and cleaner and leave it sit it drains out onto the floor, it leaks when you are using it to, is this a seal or...
Nope, not a seal problem, just natural good old fashioned natural gravity. I know it doesn\'t take long for it to start leaking after use but Bissell covers this in the manual. Thoroughly clean the unit, run clean rinse water through every cycle and empty all tanks and cavities after use. Do not leave water in any of the tanks when not in use. What doesn\'t leak on your floor (which doesn\'t take long) could cause permanent blockages in the lines. It\'s a pain, I know, but I use the garage or back deck to park and prep mine after use.
Aug 15, 2013 | Vacuums
Tip
HOW TO SPOT CLEAN A CARPET I have a "furry family" of a dog and 2...
I have a "furry family" of a dog and 2 cats who I love dearly. Unfortunately, my carpet has suffered from several "accidents" and "upset tummies". It is a challenge to find an effective cleaner that cleans the stain, reduces the odor in the carpet, and is reasonably priced.
In the past, I have tried commercial products that were both expensive and ineffective. I have also used vinegar mixed with water and, although it was effective, it did not achieve the results that I would have liked. So one day, I decided to mix a little scented fabric softener in with the vinegar and water and VOILA what a difference! It removed the stain and left the carpet soft and smelling fresh. It has become my preferred method of dealing with pet stains on the carpet.
If you decide to give this a try, be sure to test this solution on an inconspicuous place on your carpet to be sure it does not discolor or lighten it. So far, I have had only good results from its use.
To Spot Clean a small area:
  1. Fill an empty clean spray bottle with equal parts of water and vinegar. Then add a capful of scented fabric softener to the bottle. Shake it up for 30 seconds.
  2. Spray the stained area
  3. Let it sit for 2 minutes and then spray a little more on it.
  4. Rub the stain with a dry cloth until it disappears.
  5. The vinegar odor will fade as it dries and helps to remove the foul smell
  6. Let it dry and you will notice a nice fresh smell and your carpet will be soft.
  7. Once you vacuum, you will have a hard time telling where the stain was.
I have actually used the mixture above in my Bissell Carpet Cleaning machine with good results. It is much less expensive than commercial carpet cleaning solutions. Be sure to read your machine manual or contact the manufacturer to make sure it does not affect its operation. So far my machine is tolerating it well.
This is a personal tip that I just wanted to share with others. I hope you find it useful.
on Apr 12, 2011 | Vacuums
Tip
Aerus Electrolux: Don't Void Your Warranty
Aerus Electrolux Warranty
Aerus carries a great warranty on their machines, up to 20 years limited on top of the line models. However, there are some things that WILL void the warranty. The following are probably the most common.
Use of generic/made-to-fit bags. There’s a reason genuine bags are strongly advised for use with the Aerus and previous Electrolux vacuums, and it’s not just the strength of the bag. Fine dust particles will get through generic bags and result in a damaged motor.
Vacuuming wet carpet and liquids. Although you may try to make sure you don’t use your vacuum on liquids, children, other family members, and/or house cleaners won’t necessarily be as careful/caring. If kids notice the vacuum doesn’t work anymore, they may try to hide the evidence, thus you may not know about the problem.
Keep in mind that if you have your carpet steam cleaned, it can take a week or more to thoroughly dry. Vacuuming during this time will result in water/mud getting into the motor, ruining it almost immediately. A wet bag will also usually break open, sending contents through the motor. The motor will have to be replaced, but it won’t be covered by a warranty.
Dismantling of vacuum by unauthorized persons. If you’re having a problem with your vacuum, and you think it’s an easy, quick fix, don’t. You may get it fixed, but this will void the warranty for future problems. It’s simply not worth it.
Commercial use. The Aerus commercial upright is made for tougher work, but only carries a one year limited warranty. Even though your machine may have a longer, better warranty when used properly, using it as part of a cleaning or similar business voids the warranty. Solution; Don’t do it.
Aerus Electrolux does NOT warranty machines sold over the internet, such as on E-bay. Only those purchased through an authorized franchise or representative carry Aerus' warranty.
Be aware of your machines’ capabilities and warranties. An Aerus Electrolux owner has made a wise investment in a top-of-the-line home cleaning system and generally desires to maintain the system in prime working condition, with full benefits.
Contact Aerus for additional information. You can find a local shop/consultant through their home page: http://aerushome.com/
on Aug 22, 2010 | Vacuums
I have a hoover steam vac F5915-900 I bought at walmart about 4 months ago. I used it about 5 times in differnet rooms. Today when I went to use it It won;t pick up the dirty water. I cleaned the filter...
Make sure the suction area of the face plate is clear of all debris. If anything else, call the number on the machine, it's still under warrantee if the machine doesn't work from normal use.
Sep 05, 2011 | Hoover Vacuums
My vacumn has a aweful smell coming from it when in use. Not motor smell.
smells are usually from bacteria. I have seen this before and you can get O.K results by rinsing the machine with cleaning soloution. I like ****-n-span. try to use a cleaner that you like the smell of as it will leave a little of that smell behind. use the vacum in the wet type aplication and use it to **** up the cleaning solution mixed with warm water with about the same mix as you would use to clean a floor. then after the machine fills up let the cleaning solution set in there for 5 to 15 minutes. dump out the cleaning soloution and repeat the process with clean warm water. If it has gotten really bad then you made need to repeat the entire process one or two more times. I also take the pick up hose and clean it with some cleaning solution then rinse outside with a water hose.
Apr 23, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Water is coming from bottom when useing the hose.
You'll have to find out where it's leaking! Its not real hard. I will help you!
1. Fill the clean water tank. Check that the valve on this tank doesn't let water through when not on the machine. If it does this the tank is the problem.
2. Take off the 4-6 phillips screws holding the hood on to the machine. They will be on each corner underneath. Be Gentle! Do not break any of the plastic parts.
3. Check where the clean water comes to a L valve. This valve is a very common problem. Place the water tank on the machine. DO NOT hold the handle down. Use paper towel to check for wet spots if you can't see where it is leaking. It should be fairly obvious.
4. If the water is coming from the "back" of the machine or the handle pry the cover off the inside of the handle revealing the hoses. The water release valves may be leaking. Be sure to check all hoses for cracks or breaks. Simply find the water.. and trace it back.
90% of the time it is the L valve which looks like this:
http://www.vacuummedic.com/product.php?id=231
Carefully put the machine back together not forgetting anything and test!
Good Luck!!
Vac Dr.
Jan 12, 2011 | Hoover F6020-900 SteamVac Upright Vacuum
My Kenmore vacumn won`t turn on . worked fine one minute then stopped. The light works on the handle but no vacumn
You probably have a sensor that needs attention and is clogged up so unclog and see if that takes care of it
Jan 12, 2011 | Kenmore Vacuums
I have a 5.5 hp craftsman 20 litre wet Dry vacum . I have lost the manual. & have 2 questions 1) how do I change to wet vacum from dry? Also could i use the wet mode with some water in it and let it...
# 1 myou just take the bag out make sure ytou sponge filter is in place athe top and turn it on the power switch just turns on ,machine ther is no wet dry switch just an empty bagless cannister is all you need make sure the ball outlet in vacumn is working it stops water from overfilling cannister # 2 just use the proper bag and attachment to vacumn up the drywall dust a good building supply store has special sanding attachments for vacumn so you can sand and vacumn at the same time
Dec 18, 2009 | Vacuums
Won't **** up the water solution. Vacumn seem
First make sure that you are getting suction from the bottom of the machine. Most of the time the squeegee is worn out which does not allow it to pick up the water like it use to. Turn over the machine and inspect the squeegee. If it looks worn or bent then it may be time to replace it. You may also consider replacing the filter. These are the two most common parts that wear out.
here is a link the parts for your a h3000 floormate
H3000 Link
http://www.usavacuum.com/category-s/85.htm
Nov 01, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Bissell
Check the belts first, if ok, does water squirt out of the hose nozzzle, if it does then the heate in the handle asm. is clogged where the tubes hook up to it. If no water squirts out, the the pump isn't working. Pull the top cover off, check all tubes to make sure there is no clog. Make sure the tubes are routed right so as not pinch one, also make sure the piston is mounted on the smart mix knob. and the knob is in the water setting before putting the cover back on. The cap for the flow indictor is leaking are or screwed on too tight. The seal at the bottom of the tank is not on the tank and is missing or sitting in the hole where the water goes.
Dec 23, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
