Question about Dymo LabelWriter 400 Thermal Printer
Continual feeding of labels?
My Dymo 400 model 93490 just started continually feeding labels and it won't stop? I've changed rolls, but it feeds and feeds non stop. Have opened up and checked and there is nothing covering sensors or any stuck labels. All was fine till I changed a roll of labels. Have been using compatible labels, but have also tried genuine ones.
  • GR8PICS May 24, 2008
    Thanks for trying, but not the case. I have sent off for repairs to the faulty paper advanced sensor.
  • Anonymous Mar 31, 2014
    I was working on a project and it stop feeding the blank cards, now it wont feed, its stuck or something.
  • 28 Answers
The settings of the printer must have been changed
Posted on May 24, 2008
The print is faded at the bottom of the card
If the problem started when you changed label rolls, the problem is most likely the newly installed label roll. In the picture below is an extract from the Dymo Users Guide going over print quality issues.
Dec 17, 2014 | Dymo LabelWriter 400 Turbo Thermal Printer
The labels feed no problem but it wont print anything on the label
I had this happen to me before. First try another roll of labels. Then call Dymo. If it is under warranty they will fix/replace it. If it is out of warranty they might be able to give you a discount on a replacement which is what I had to do.
Apr 18, 2011 | Dymo LabelWriter 400 Turbo Thermal Printer
It begins to print then stops half way
Having the same problem here... very random... send a print job of labels and it will print the whole lot, or freeze at random points but always halfway through a label... no error message... unplug usb and replug doesnt do anything, but unplug and replug power and off it goes printing more lables but may even freeze again after only a few more have come out... also, every day the first print job of the day prints half the label and pauses for about 10 seconds then keeps going...
- Windows XP Pro SP3
- LabelWriter 400 as supplied out of the box
- Genuine DYMO labels
Jan 28, 2011 | Dymo LabelWriter 400 Thermal Printer
My Dymo Labelwriter 450 turbo feeds out 4 labels each time I print one. The print setting is on one label. The first one prints and the next three are blank. If I try to use the reverse button the printer...
Multiple label feeding usually occurs because the sides of the spool holding the roll are not squeezed tightly together. Make sure there's no gap between the labels and the sides of the spool. If this doesn't help. take out the labels and blow a blast of air into the feed slot. There is a sensor inside the slot on the left that detects the hole in the labels, and maybe it is blocked.
Jan 26, 2011 | Dymo LabelWriter 400 Thermal Printer
Dymo prints blotchy labels and feeds out many labels after print
Sounds like you have a couple of issues going on...your labels are incompatible or you have an incorrect template selected in the Dymo Software.
Check that the label model matches the template and you are using quality Dymo Labels. Such as the Dymo name brand or the LabelValue brand Dymo labels.
Apr 30, 2010 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo labelwriter 400 Turbo -We replaced the roll of labels and it keeps feeding with no stop
There are a few common reasons this is problem can exist.
1.) the incorrect template is used when creating the label
2.) the labels are installed incorrectly - the labels must be loaded and pushed against the left side of the printer and lid closed when printing to ensure the labels don't "wander" out of the sensor's view.
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view. Use quality Dymo labels.
4.) The labels are defective - if you have another roll of the same size, try it to see if it has the samme issue.
Oct 17, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo 400 labelwriter does not print unless shut down and rebooted
It could be how you have loaded the labels. If you have loaded the labels and there is a small gap between the spindle and the roll, it will print one label and give a error-printer message and stop working until you unplug it for 30 seconds and plug it back in. I would reload the labels from scratch and ensure there is no gap.
Feb 17, 2009 | Dymo LabelWriter 400 Thermal Printer
CONTINOUS FEED
Use a DYMO Label/Writer Cleaning Card #60622. One should have come with your printer. Just remove the labels, run this cleaning pad through a few times, insert the labels, and print.
Sep 02, 2008 | Dymo LabelWriter 400 Thermal Printer
Labels Print Once Then Fail (3.5 X 1)
"The printer will print one label then either push out a half a blank label or several blank labels. At that point the labewriter thinks it's out of paper. I also noticed that the labels tend to slide toward the middle while exiting. After each print I have to pull the labels back in and realign them. Then the process repeats."
This is because you haven't squeezed both sides of the spool to the edges of the label. Without the sides to hold the label in place it is free to slide about on the spool and therefore slides about where the print head and label sensor are. The sensor is on the left, so if it slides towards the middle the sensor can't see the label and reports "out of labels".
See the diagram here for a clear picture of how to correctly load the labels to avoid this problem:
How to load Dymo LabelWriter Labels
Nov 06, 2007 | Dymo LabelWriter 400 Thermal Printer
Dymo LabelWriter 400 Thermal Printer Logo
1,725 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
