Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Water dispensor does not dispense water. Ice maker works.
The water dispensor does not dispens water. Ice maker works fine. I put a new filter in and the filter filled with water but still no water from dispensor.
  • 1 more comment
  • daveyjoe May 21, 2008
    The water flow is very slow, even after replacing filters. Any ideas?
  • Anonymous May 22, 2008
    same problem - we just had a power outage and when the power returned the water will not dispense. The water flow was very slow anyway. Ice works fine, but no water.
  • Anonymous Mar 16, 2014
    how to bleed the air on a water dispensor and ice maker after changing water filter on a kitchen maid model
  • 1,224 Answers
You have prime the system air out of the water lines this is easy to do
put a glass big enough to cover water dispensor outlet cause its going to project water out at you press and hold button till water starts to run smooth
these fridges will spit water at you when you prime the system at first cause theres air blockage in lines
Posted on May 20, 2008
  • Christophe Thompson
    Christophe Thompson May 21, 2008
    make sure daveyjoe that they didnt put an extra filter on the back of fridge connecting under counter sometimes services do this for better water flow taste
No water in water dispensor
Don't forget that your dual water control valve has two sides. One side is for the ice maker and other side is for water dispenser. The water dispenser side may have recently failed causing water to not enter water filter area or dispenser, Thanks Sea Breeze
Feb 21, 2012 | LG LRBC22544 Bottom Freezer Refrigerator
Water dispensing but also leaking from the back
Pull the fridge out and remove the back panel . Have someone press the water dispensor and watch for the leak . Usually , the plastic line at the water valve breaks off , and removing the broken piece and reinserting the line , fixes it . You may have to remove the 1 screw holding the water valve on , to gain access to remove the broken piece of line . The water valve itself , could also have a hole in it , spraying , due to long period of water pressure . Just replace the water valve , if this is the problem .
Sep 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water not coming out of dispensor
two problem one water vale are the line were water come out is frozen the water splashes back and line freezes are water vale leakes
Jun 01, 2009 | Refrigerators
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PROFILE PSS26msrd Ice maker not working water dispensor ok new water valve new filter fill tube seems clear Does anybody have any sugestions before i replace the ice maker unit?
water does become ice inside the pipe in side the freezer it happens to my frige at list once a year, put a hard wire or pencil up to make sure that is not the problem, before you spend any more money
Dec 06, 2008 | GE Profile PSW26P Stainless Steel Side by...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
514 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
