Question about Samsung TXP2675WH 26" TV
Sound but no picture
I have a Samsung TXP2675WH and whin I wnet to turn on the TV there is no picture. The sound still works and i can hear the TV but it will not show a picture on any of the inputs.
    Genius:
  • 1,224 Answers
Well if any i can say with out seeing it would be straight off my head 2 things
1 the bulb blew out
2 the input settings on remote were accidently pushed to another setting which the tv now has no picture
if you still get a menu from your remote on tv that means that some how you clicked a remote setting input if you dont get the menu then the bulb blew out
Posted on May 20, 2008
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Once we turn the tv on it would start making a sound like a whinning high pitch sound with no picture..and it wont turn off anymore unless you pull the plug..
hello jackiea0819,
pich sound on HLR6768W because of the collor wheel. The color wheel not rotate properly.
My suggestion you replace the color wheel. Call samsung technician to replace it.
Good luck.
Mar 29, 2011 | Samsung HLR6768W 67" Rear Projection HDTV
I have a 19 inch emerson lcd tv that has no picture and as u plug it in the tv makes a whinning sound but as soon as u unplug it the sound goes away
More than the tv power supply board have problems in this tv,don't know yet.But the whinning sound,the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.First must see how it turn out.
Dec 08, 2010 | Emerson LD195EM8 19 in. LCD TV
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
Feb 27, 2010 | Televison & Video
Loud whinning noise then no picture or sound
Color wheel is the noise you are hearing. It can also keep the lamp from firing up if it has seized up. Remove the lamp and inspect it. Replace the color wheel for sure.
Jan 10, 2009 | Samsung HL-R5678W 56" Television
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
there are several things that need to take place for the lamp to turn on. first the color wheel needs to turn on ( if you can hear a whinning noise then this is fine) next the tv will send a signal to the lamp ballast to turn on, and the ballast needs the 130v dc supply from the power board ( simoly remove the lamp and reinstall the lamp door, turn tv on, and if you hear an arcing noise from the ballast you know this is fine too. the board that controls all of this is the dmd board. so if the color wheel works, ballast starts then i would replace the dmd board....
Oct 24, 2007 | Samsung HLP5085W 50" Rear Projection...
SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
I have the same problem... It turns B&W
I can still hear the sound... however I can still turn the tv off when that happens
Aug 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung TXP2675WH 26" TV Logo
136 people viewed this question
Henry  Thomas
Henry Thomas
