Question about Pioneer Audio Players & Recorders
I cant get the speakers to work on my pioneer receiver model vsx3300. there is no noise at all from them.
  • 151 Answers
IFF YOU HAVE NO SOUND FROM ALL SOURCES TRY RUNNING A TEST TONE ,IFF YOU GET A HISS FROM EACH SPEAKER MAKE SHURE YOU HAVE TOLD THE AMP WERE EACH SOURCE IS PLUGED INTO.
HOPE THIS WORKS IFF NOT YOU MAY HAVE 2 GO BACK 2 YOUR DEALER AND SEND BACK 2 PIONEER.
PS,ARE YOU SHURE YOUR SPEAKERS ARE NOT BLOWN?
CABLE GUY.
Posted on May 20, 2008
Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Jan 03, 2008 | Pioneer VSX-54TX Receiver
Tip
How to make a Pioneer vsx-816k/s last longer
I really don't recommend this product to anyone, or any newer pioneer products for that matter (except the elite line). This model has the "hybrid" design, which is a very flawed design. At first the speakers will start cutting in and out, and then some of them wont work at all, and then the receiver will flash "overload" and the receiver will go into a permanent protection, all because the receiver cant handle the resistance of the speakers(doesn't matter what speaker it is). Once in protect mode, press ENTER+ ADVANCED SURROUND and it will tell you what the problem is causing it to stay in protect mode. In order to keep this from happening, use external amps. Pioneer wants around 500 dollars to fix it if its out of warranty, it will cost at least 50 to fix it yourself, in most cases it will cost 150 to fix it yourself (most cases all 3 power modules will go out, or as pioneer calls them, power packs). If you have an older vsx model (50s-80s) then it is usually worth fixing. If your having problems with pioneer vsx 3600, 3700s, 3800, or 3900s, send me an email at Joshadk@embarqmail.com and i will help you the best i can
on May 16, 2010 | Pioneer VSX-816-K/S Receiver
Connectivity
you have to make sure you are on the theater mode on your amp. that's the only time that the center speaker works
Jun 10, 2010 | Pioneer VSX-818V-K Receiver
Crackling sound on my amplifier
If you have good clean, loud sound with your LP player and not with your PC, your PC is causing the noise. Most PC sound cards are not very HiFi in their sound and it is quite evident when listening to a PC via a HIFI sound. Now, you can not use the headphone outputs to your Pioneer, you must use the LINE OUT jack, set as line out in your computer. There is a signal level mismatch if you use your headphone outs, distorting your Pioneer. Try LINE OUTs or buy a HiFi rated sound card.
Feb 23, 2010 | Audio Players & Recorders
Pioneer receiver shuts off
This might not be any help to someone else, but I fixed the problem by double checking all the speaker wire connections - on the speakers and behind the receiver. A couple banana plugs felt loose and I discovered that one connection on one speaker was out completely. Suppose I should have seen that sooner, but as soon as I ensured all the wires were where they were supposed to be, I encountered no more problems.
If your Pioneer receiver is shutting off on you, double check all your connections!
Jun 19, 2009 | Pioneer Elite VSX-9100TX Receiver
Sub woofer
The subwoofer is totally independent from your Pioneer VSX-D412. You can check if it works like you did with a finger on the hot point of the RCA cable (not very good test, as you will hear noise and can't say if that means it works OK) or better connect a known receiver to the speaker connections in the sub and test to see if it’s working properly.
Regarding the receiver, you may not have enabled the VSX to output to the sub. Read the manual on how to check for that. Only Dolby Digital 5.1 signals will allow the sub out, in a receiver of this level. It normally will not let you use the sub in stereo mode. Some more complex units will allow you that, but I believe not this model.
Good luck
Nov 01, 2008 | Pioneer VSX-D412 Receiver
Pioneer 6400 car stereo
check to see if any of the other speaker wires are going to ground -it sounds like one or more of them are
Apr 02, 2008 | Pioneer DEH-P6400 CD Player
82 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
