Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Amana frig I have a Distinctins Amana bottom freezer. The freezer is not really freezing & the frig is not real cold. What could the problem be?
  • 828 Answers
1.Dirty condenser coils where heat is transfered to the room air. 2.Frost build-up on back wall of freezer section which would indicate a defrost system problem.
Posted on May 24, 2008
Freezer freezes but frig wont cool amana with freezer on the bottom
I couldn't find a repairman so I pulled the big thing away from the wall, took off the bottom front plate and the bottom rear plate and unplugged the big beast. Then using a refrigerator brush and a vacuum I carefully cleaned all the dustballs from the coils on the bottom. Then plugged it back in and in about 3 hours it was cooling normally again on a "4" setting.
Jul 13, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana refrigerator not cold
The fan that should circulate air between the two compartments has failed. These usually have 'sleeve' bearings which can become sticky and fail to start up without help. Go to the Sears/parts website and enter your Amana model number; if you are lucky, they will have a line drawing of your model which can aid in finding how to access the fan:
Sears Parts Dept.
They have info for thousands of non-Sears items and most can be ordered via that website as well.
Feb 25, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer on the bottom
Because there are many models like the model number listed above your post I will need you to confirm the model number on the refrigerator. The photo below shows were to look for the model number. Some like yours have a simple defrost system and some have circuit control boards. Everyone has these problems with every brand, Your model is Amana and also a Maytag brand. Let me know so I can help you get this going thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 28, 2009 | Amana ABB1927DE Bottom Freezer...
Ice cream and bread don't freeze, food in frig DOES freeze
Not fixed but I do not want to spend MORE money to find out what's wrong with this AMANA piece of ****. Apparently, from research on the net, the compressor or motor is not strong enough in this unit to actually do the job...but if anyone has any suggestions, I'm happy to hear them...
May 16, 2009 | Amana ATB1832AR Top Freezer Refrigerator
I have an amana side by side refrig, the frig side cools a little
sounds like yhour compressor is not runnning, look behind the unit and se of the fan down below is turning and if the compressor is cold, or overheated and redhot
Mar 09, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Amana side by side does not freeze nor does it get cold
first check you freezer back for frost if a lot of frost defrost the whole freezer ,,, then plug back in and see if it will work..
let me know
Jul 05, 2008 | Amana SXD524VW Side by Side Refrigerator
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
129 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
