Question about Frigidaire FRS26R4A Side by Side Refrigerator
Help in North Carolinia
The frigidaire gets cold, the freezer and fresh food department cools real good. it even makes ice with no problem at all. but with in a day or two it warm again. I unplug it for a day and plug it back in and it gets cold again. but within a day or two at the most it is warm again .
    Genius:
  • 1,073 Answers
If you look inside the freezer you will see frost on the back panel of the freezer, you ar defrosting manually, the issue is either a defrost heater a defrost therinastat or a defrost timer, the timer is an adaptive defrost timer and is in the fresh food section of the ref, gut feeling is defrost timer but one of the three, a ohm meter will tell you if the heater and the thremastat are good if so the timer is the problem
Posted on May 20, 2008
Why on my model FRS6LR5EW3 freezer side is working maintains ice but fresh food side is not working, no light, no fan??
Good Morning Friend,
I understand the freezer portion is working on your Frigidaire refrigerator, model# FRS6LR5EW3, but your refrigerator does not seem to be as cool as it should, due to the fan not working. I also see that the light is not working, even after changing it out. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and see if the light is on. Also, listen for the fan to run and give the refrigerator portion of your appliance 24 hours to stabilize at the set temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 09, 2014 | Frigidaire Refrigerators
Frozen water lays in the freezer bottom. unit is a KXX not the KXK
I have seen this before. Instead of the water draining out the drain hole it puddles between the freezer and fresh food department. The freezer is fine but the cold air from it cannot get down there and cool that fresh food!. Solution: Thaw out the whole ice box and clear the drain hole of the obstruction and party on.
Dec 30, 2010 | Whirlpool ET1FTKXK Top Freezer...
My side by side freezer is working fridge wont get cold,compressor is working.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require a service technician to check and repair these components.
Hope this was helpful. Good Luck.
Aug 29, 2009 | Frigidaire FRS26R4A Side by Side...
My refrigerator is running but my lower portion is not cooling. The freezer part is plenty cold and keeping my frozen foods frozen. Why would the lower part of the fridge not cool?
Aug 29, 2009 | Refrigerators
Bottom of fridge not cooling
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Aug 29, 2009 | Estate Model: TT16DKXSQ Top Freezer...
Fridg is not working right
Aug 28, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Have Sub zero side by side 561 Why does the temperature control not increase the cooling of the refrigerator? The milk and vegetables are spoiling.
Aug 28, 2009 | Refrigerators
Fridge doesnt stay cold
Aug 28, 2009 | Maytag MZD2766GES Side by Side...
Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
67 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
