Question about Linksys Wireless-G WRT54G Router
WIRELESS CONNECTION LUTHER Signal strenght is excellent but cannot connect laptoy wirelessly - using XP How do I make sure that the SSID is same on both router and computer?
  • 86 Answers
Login to router, change the SSID password
Posted on May 20, 2008
My wifi doesn't work.
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 08, 2012 | Computers & Internet
HOW DO I GET THE INTERNET USING MY PSP?
You need to connect it to a wireless network, from the home screen go along to settings, down to network settings, choose a mode, (Infrastructure should work fine) New connection, Scan, (here you should see your SSID and signal strenght) choose security type that your wireless network has. enter any security details such as WEP key. Choose Easy for address Setting, choose a connection name. (Home) Save it and then test the connection, if it fails it should show you where it fails along the line.
Hope this helps
May 05, 2011 | Sony PlayStation Portable (PSP) Console
Installed Trendnet wireless adapter. Connection shows excellent but can't browse internet
The "excellent" is the signal-strength between your wireless adapter
and your wireless router.
You still need to select the SSID ("network name") that you configured into the router, and enter the password for your network, before you can connect to the Internet.
Compare it to having a brand-new mobile telephone. Until you dial a friend's number, and the friend answers, all you have is an "excellent" telephone.
Feb 21, 2011 | Trendware TEW-423PI (ASKU44090) Wireless...
Wireless Network Connection constantly reading low/vlow/no signal
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
Jan 04, 2010 | Computers & Internet
Attempting connection of a hp photosmart 7200 printer
What is the brand of your wireless router? Just make sure the SSID (signal's name) is configured on the wireless setting of your printer. They should have the same SSID configured. If the correct SSID is already configured on the printer's wireless settings, try to change the channel on your wireless router. Use channel 11. You can also try to do a power cycle. Turn off your wireless router and printer for about 1 minute. Power on router first, wait for the lights to stop blinking, then power on your printer.
Oct 10, 2008 | Linksys Wireless-G WRT54G Router
Wireless router not detected by laptop
Hi!
First, make sure you know the SSID (name of your wireless network) and Network key (if your wireless router is secured). Also, make sure that the SSID broadcast of your laptop is enabled (this is an option in the router if they will broadcast the signal or not).
I assume that your laptop came with a built in Broadcom adapter. Depending on the brand of your laptop, there is always a wireless switch. You need to look for the wireless switch and turn it ON. For most laptops it's a sliding switch on either the side or front of the laptop. For some it's a combination key - like pressing FN + F2 at the same time.
For XP laptops, you can use the XP wireless utility located on the lower right side of your screen like this :
For some reason the XP utility cannot detect any signal and it's telling you that "Windows cannot configure this.. if you enable another utility, use that software to connect", that only means that there is another software in the computer that is running the wireless connection. You can go to Start > All Programs and look for that utility - you can start by searching a program like broadcom.
For Vista , look for this icon to connect:
I hope that helps.
Good luck and have a nice day!
Oct 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Enuwi-g2 problems
What operating system are you using, Win XP?
Go to the control panel - look at Network Connection, click on properties on your USB adapter, click on Internet Protocol (TCP/IP), then Properties, make sure Obtain an IP address automatically is selected.
Also make sure your USB adapter settings (SSID, WEP/WAP etc) matches your Access Point settings.
Mar 04, 2008 | Encore Wireless Ethernet Network Adapter
Connection to ps3 drops in and out
GO to network settings...Check out Settings and Connection status list...make sure everything is enabled, wireless, and Automatic....reset your connection..and ur router....turn off the WEP ...security disable....
internet connection : Enabled
connection method : wireless
signal strenght: 100%
SSID : (name of your wireless router)
Security: i set NONE....no one really cares to hack ur PS3 ppl turn this off
Address settings : AUTOMATIC
Feb 11, 2008 | NetGear DG834G Router
Wired works fine wireless does not
what is your ip and subnet addresses? are they complete? sometimes I enter my own in the alternate tab. eg.
ip; 192.168.1.105
sub; 255.255.255.0
gate; 192.168.1.1
dns; 192.168.1.1
alt dns; 192.168.0.1
Dec 31, 2007 | NetGear DG834G Router
WIRELESS NETWORKING
There are several problems reported that may cause disconnection. First is the hiding of the SSID (wireless network name) and enabling WEP or WPA encryption. The recommended solution for that is to unhide the SSID in the router configuration.
Second is that there are more and more wireless devices and occasionally interference occurs on a single channel (even from non computer devices like wireless phones. As routers are often set to channel 6 you may be competing for radio communications with your neighbors. The recommendation is to switch the router to either channel 1 or 11. If your first choice does not work try the other.
Dec 24, 2007 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Linksys Wireless-G WRT54G Router Logo
70 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
