Open a laptop
Compaq presario v6741 us - cannot open the lid to the laptop to get started... Where is an "open" button located? Front, side, back, bottom? thanks
    Champion:
  • 207 Answers
U dont have any button to open the lid it is lil tight app lil force not too ...
Posted on May 20, 2008
Where is the wireless button on the compaq presario 1600
The wireless button may be on the very front of your laptop. The button location is on the front side, not actually on the keyboard side of the laptop, it will be directly facing you on the front side of the laptop. There should be a switch / button to press that will turn it on and off. A blue light should light up once you have switched it on to show you that the wireless is active.
Mar 28, 2012 | Acer TravelMate 2480 PC Notebook
Screen won't come on when laptop powers on
1. Software
- Try Fn + F5 or something like that
2. Electrical
- Remove battery, unplug power, hold power button for 60 seconds, turn on computer with power plug only, then shutdown, add battery and restart
3. Magnetic On/Off Switch to detect of Close/Open Lid
- Your magnet switch is fubar some how. Open up the speaker cover and see if your lid actuator switch that come in contact with the magnet on your lid cover is stuck or not (find where the magnet is in the back of the front lid cover, trace where the magnet area actually touches the base of the computer and you will find the switch)
- Workaround, start windows with lid at 30 degree angle
Toll Free: 877 407 9229
any doubts you can get in touch with the best pc doctor through
www.thebestpcdoctor.com
Oct 01, 2011 | Compaq Presario CQ60-220US PC Laptop
Is there an internal microphone and if so where is it located trying to record myself i have a compaq presario 2200
Hi, the HP Compaq Presario 2200 PC has no built in or internal microphone. You will have to purchase an external one to record audio. The microphone jack, when viewing the laptop from the front, is located on the left side.
There are small round holes which are jack ports. From the front to the back, the microphone port to plug in a microphone is the second hole back. Here is a manual in case you need more help with your laptop: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 22, 2011 | HP Compaq Presario 2200 Notebook
I have a compaq presario CQ61 and i turn it on and everything works but my scrren stays black. what is the problem?
HI
First of all if you can remove the ram memory DO IT SO ifyou cant try without removing FIRST.
-remove battery pack(if you can romove memory ram aswell) and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILLSTART ONCE YOUR SYSTEM BE READY SHUT IT DOWN PUT THE BATTERY PACK BACK ANDCONTUNUE TO USE YOUR LAPTOP
Feb 26, 2011 | HP Compaq Presario CQ61420us Notebook
On off button not working
We need to follow some Troubleshooting steps
power off the tower
disconnect the power cable
1.open the side panal of the tower
2.then open the front panal of the tower
3.the please toggle the power button from inside the tower
4.then put back the front and the side panal
connect back the power cable
restart the pc using the power button
it will start working
Jan 13, 2011 | HP Compaq Presario SR1830NX PC Desktop
How do i remove the outer bezel on a compaq presario cq61? i need to replace the screen. compaq presario cq61-110sa
1. Take the side door off as usual.
2. Locate the drive door lock inside the chassis.
3. Rotate the lock to the down position to unlock the upper front panel door.
4. Press the indentation located on the lower front panel to open the lower door.
5. Grasp under the bottom of the upper front panel door, lift up, and gently remove from the hooks. (Tip: The upper front panel door has finger holes.)
6. Remove any of the bay components by pressing both sides of the drive rails. There are no screws.
hope this helps...........
Mar 14, 2010 | Compaq Presario Notebook
Where is my wireless switch on my Compaq Presario R3000
Right side in the front at the corner ,,little round button ,,it will glow blue when on,,
Dec 13, 2009 | Compaq Presario R3000 Notebook
I need to know how to replace the display hinges on my presario
QUICK METHOD
1) Hinges supplied on ebay at about £15 a set. Non original parts seem fine.
A mini screwdriver set of decent quality with a magnetic feature helps & Duck (duct) tape.
2) Switch off and remove from mains source. Also flick battery holding switch and push out main
battery. Remove small Phillips screws under battery.
3) You can try the 'quick' method and not undo the whole of the base screws BUT be very careful
as you work not to damage the 2 sets of wires passing through the LH and RH hinges.
4) Pry off the long back top cover near hinges which has the start button on it and 'Presario' written
on. You do this by pushing from front just under F2 F3 SCROLL and PAUSE keys as well as from
the back. If you hold the keys down as you pry this helps. Use a thin blade of driver but be careful
not to split the thin plastic. TAKE YOUR TIME - BE FIRM BUT DON'T FORCE. Work round it
and it will eventually pop out upwards.
5) You have now access to the hinge cover(s) so remove these and also offending hinge(s) from main
body.
Don't let the lid sprain the hinges even further or break as existing good one! A temporary
hinge of Duck taping lid to base may help.
6) Take out the little grey rubber plugs from the screen side of the lid. They can be stuck back after.
Unscrew silver phillips screws (6 or 8 I think).
7) The plastic front of lid should now pry off and whole top opens up to reveal the side hinge
fastening. Unscrew little black screws and keep safe. Then carefully extract hinge.
8) Refitting basically just reverse of above. Hinges are naturally stiff to hold the screen so open
them up to the best angle to get all hinge screws in. A magnetic screwdriver does help!
Also, if both hinges have gone do one THEN the other to avoid pulling the lid cables too much.
I did mine, hinges fine and laptop still works!
Mar 12, 2009 | HP Compaq Presario V5000Z Notebook
Wireless connection
The button is located on the front edge of your laptop. It is a slider type button. Tip the laptop up so you can see the front and lok for the wireless icon with a light next to it. The button to the left of it is your switch.
Mar 08, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario F500 Monitor Problem
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01480071&dlc=en
This might fix your problem. There is a problem sith the bios on select F500 models. Yours might fall in that category.
Aug 29, 2008 | Compaq Presario Notebook
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
