Question about Frigidaire 27 in. Electric Double Self-Cleaning Wall Oven
FGB24L2ABB Frigidaire wall oven
When you try to set the oven temperature the colck flashs 12:00. When you reset the clock & start over & set the temperature it go back to 12;00
thank you thomasgeoel@aol.com
  • Anonymous Mar 27, 2014
    temperature
Local outlety to buy rack for oven
jeff
Posted on Nov 12, 2008
Used the self cleaning option and now top oven will not heat?
Good Morning Friend,
I understand you used the self-clean option on your Frigidaire oven, model# FPET2785KF, and now the top oven will not heat. I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "set clock" button, entering in the time, then pressing the "start" button. Set the upper oven for any cycle at any temperature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your wall-oven status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Professional 27 In. Stainless...
Why when i used the self cleaning option on my upper oven will it not heat anymore?
Good Morning James,
-Best Regards-
WP
How to fix frigidaire wall oven beeping error message f11
I understand that your Frigidaire wall oven is beeping and showing an F11 error code. Typically an F11 error code states that there is a shorted key, or a button has been detected as pressed for a long time. I suggest hard resetting your appliance, by cutting the power at your homes circuit breaker for 3-5 minutes. While you are resetting your oven, make sure to wipe down the control panel. The panel is very sensitive and could be detecting something that has splashed or spilled onto it, even dust. When you bring power back to your appliance you will need to start by setting the clock. Turn your oven on any cycle at any temperature. If you are still receiving an F11 error code, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 14, 2014 | Frigidaire 30 in. Electric Gallery Series...
How do you reset the frigidaire wall oven?
Good Afternoon Friend,
I understand you are trying to reset your Frigidaire wall oven, model# FEB27S5A, due to it not heating above 100 degrees. I suggest resetting at your homes circuit breaker for 3-5 minutes. When you restore power, you will first need to set the clock. After setting the clock, preheat your oven. If you are still noticing that the temperatures are still not going above 100 degrees, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to not reach the desired temperatures. Hope this is helpful.
-Best regards-
WP
May 11, 2014 | Frigidaire FEB27S5A Electric Single Oven
Why can't i set the temperature on my frigidaire oven model # FFGF3053LSC? Burners work. I have unplugged it and plugged it back in. I have checked the circuit breakers. It still does not work. ...
Good Afternoon Annette,
I see that you are having trouble setting the temperature on your Frigidaire oven, model# FFGF3053LSC, even after resetting it by unplugging it. First I would make sure that you are able to set the clock as well. Try setting the clock by pressing the clock button and then pressing and holding down the up or down arrows to change the time. If you are able to do this and not set your oven, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why you are unable to set the temperature for your oven. Hope this helps.
-Best Regards-
WP
Apr 25, 2014 | Frigidaire Ovens
Oven is not working its 5 years frigdare electronic elements are ok
Try setting clock before presuming board is faulty, ovens shouldn't work if clock is flashing or timer is counting down or bell symbol flashing. Consult your instructions
warmest regards
Richard The Repairman
Mar 29, 2014 | Frigidaire FEB30S5D Electric Single Oven
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
My oven is saying "stop" . Previously to this is was showing F02 and the fan wouldn't turn off. We turned the main switch for oven off and back on and it now says "stop"
Previous fault F02 is indicating an overheat fault- service manual says to replace main electronic control board. However, switching off at wall has reset the clock- you need to set the time before the oven will work-press middle button until small triangle is next to clock icon, set time using temperature dial. Once clock has ben set, try using oven to see if F02 fault reappears- sometimes switching off at wall will clear fault. Good luck!!
Mar 16, 2010 | Whirlpool AKZ159IX Oven
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Frigidaire 27 in. Electric Double Self-Cleaning Wall Oven Logo
202 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
