Question about Kenmore Dryers
Where are the manuals?
The website implies I can get a manual. I can't find one. ????
I need to open up the dryer to get at the drive belt.
Chris
    Genius:
  • 1,073 Answers
No on board manual to tell you how to install a belt
Posted on May 20, 2008
Haier dryer RDE/RDG 350AW
Replace the drive belt must have slipped off maybe loose from use.
It does say in manual to store and move in an upright position.
Sorry don't have a reapir manual but crack it open, and either fix the belt if it has slipped off its tension pulley or you will need to replace the belt just did my LG dryer last weekend a 4 out of 10 difficulty,,,about 1and half job....belt costy me $25.00 hope this helps some.
Jul 23, 2014 | Haier Dryers
Where should i look for the belt location inside the drier? the drier has heat, its making nois as a motor is ok but do not rotate anymore
If you need to find parts or manuals for the dryer, go to Google website and type in you model number and then type in what you need manuals or parts. More then likely your belt came off the idler pulley.
May 11, 2011 | Estate TEDS840JQ Electric Dryer
To replace the belt on GE Dryer DISR473DG1WW, we will need to open the back of the cabinet, right? Is there a repair manual showing the process? Does this dryer ship with a spare belt inside?
Hello, W/D here.
I'm not aware of any dryers shipping with a spare belt on board, but this may vary by region.
You are correct in that the back is removed to gain access to the belt. Disconnect the power first. If there isn't a spare in the cabinet (probably not), take the old belt with you to your local appliance parts supply house and get a replacement, or it may be ordered on-line. The belt number will be on the belt.
Here's a good website showing how your model is assembled. This site also has parts descriptions and prices; useful for comparison shopping. There is also usually a button-link to a free downloadable manual. Here 'tis: http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dryer-Parts/Model-DISR473DG1WW/0432/0151200?pathTaken=&prst=0&shdMod=DISR473DG1WW
Another good site to check for parts is: http//www.appliancepartspros.com.
Armed with these items, replacing the belt will be child's play for you!
Best regards, (and please rate this solution), --W/D--
Apr 02, 2011 | GE Dryers
I have a kenmore 80 series electric dryer. It gets
If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Thanks for choosing fixya...Regards, Joe
Nov 13, 2009 | Cars & Trucks
Help Changing Belt on Maytag PYET444AYW dryer
Normally if it is a front loading machine then you need to take the front of the dryer off.
This will expose the drum, roller, etc.
Remove the drum, install new belt on the motor pulley, loop around the idle arm roller, then install on the drum and reinstall the drum, reinstall the front and job complete
Sep 26, 2009 | Maytag Dryers
GOT A SQUEAK AND NEED TO REPLACE DOOR GASKET NEED TO LOOK AT BOOK ROPER DRYER MOD.REX4634JQO
The Roper is manufactured by Whirlpool. Your REX4634JQO should be identical to the Whirlpool LER 4634 J. Go to Roper's website at www.roperappliances.com/support to see about getting a manual. If you want to get at the problem without waiting for a manual, take a putty knife and slide it under the top of the dryer at the two retaining clips to pop it open and tilt the top back exposing the top of the drum. Then open the bottom panel and take the belt off the motor pulley. You should then be able to lift the drum out of the enclosure. Clean off the ball and socket at the back of the drum and apply fresh grease. Clean the lint off the idle rollers at the front of the enclosure and make sure they turn freely. Clean the surface where the belt rides and clean off the belt, then reassemble. If the belt is glazed, frayed, cracked, or shows any other wear or damage, do yourself a big favor and replace it now. I think the last one I bought was about $12 and will save you the trouble of doing all this again when the belt does finally fail.
Mar 04, 2009 | Roper REX4634KQ Electric Dryer
Dryer does not tumble, but heats up
Click here for a belt installation diagram.
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
if this helps please vote me a fix ya
Jul 15, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Replacing clutch drive belt dyson dc14
Hi.
There are 2 belts on the Dyson clutch unit which can both be replaced.
Its a lot to discribe so try this site for dyson service manual.
http://dysonmanuals.inc.io/
Chris..
Dec 13, 2007 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dryers Logo
76 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
