Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sleep light Model # kv-25xbr Sleep light is on and can't seem to get the tv to turn on. Any suggestions?
I've had this problem a few times... all I do to fix it is hold down thee sleep button and the power button on the remote at the same time for about 30sec... quickly release the sleep button, and press it again (while continuing to hold down the power button) to allow the power to switch on/off ... sometimes I have to do this a few times in a row... but it's worked the last 4 times my TV did this...
Posted on Aug 25, 2008
Self diagnostics?? meaning, needs to be taken in??
Posted on May 26, 2008
    Problem Solver:
  • 11 Answers
I have a simular problem with my sony kvfs120 32, my stand by timer is flashing and the tv will do nothing else. the flasing light is actually a self diagonistic code mine is flasing 5 times.
Ray
Posted on May 23, 2008
Sony trinitron tv is in sleep mode how do i turn sleep mode off
Check this link and download the user manual to your TV. Refer it. It have all details.
Feb 06, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
(Kv-27tw70) sleep is the default status and Causes tv to turn off after 30 seconds or so...no Remote, what do I do?
Aquire a remote control and turn the sleep option off. It cannot be done otherwise.
Jan 03, 2011 | Televison & Video
We have a Sony Trinitron Color TV that seem to be in a sleep mode and we can't turn it on. Would you know what the problem is?
Hello
Press the "Sleep" button on your Sony's remote control hanset until the TV displays the time in minutes [ 15,30,45,60 or 90] that you want the the TV to remain "on" before shutting "Off" automatically. Cancel by pressing until "Sleep Off" appears. The logo also will go out from the screen.
You just do this after unpluging the TV from AC wall socker for about 10 minutes or so, and then plug it.
Nov 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hello- I've had a few power outages My WEGA keeps going on SLEEP MODE Any ideas Thanks- Alan
It may seem like sleep mode, but what it actually is would be low power mode.
Your voltage may not be sufficient to power the set properly and overheating occurs.
This is sometimes confused with sleep mode which has a different set of warning flashes than sleep mode from the LED light though they are the same color.
I would have the power checked on your outlet before attempting to repair the set.
I'm almost willing to bet that it reads at 90+ volts AC Rather than the rated voltage of 110 or better.
Oct 29, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
No picture
your sony ctv is in sleepmode. so kindly press sleep button at remote control .other wise you swith off tv ( that means remove the mains wire from pluck point) then after 5 minutes switch on it will OK.
Aug 02, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby light is flashing 10 tims Model KV-HR36
Try unpluging your T.V. for 5hours+, then turn it back on. Worked for It's called a "hard reset" by sony.
Otherwise
Do the following steps
  1. Check the Sony remote for a button labeled "Sleep." This allows you to cycle through the sleep settings and determine how long you want the TV to remain on.
  2. Step 2 Press the "Sleep" button. You'll see a number come up onscreen: usually 15 or 90. When you press it again the number changes, moving up and down in increments of 15. This is the number of minutes the TV will remain on before it goes to sleep. As you cycle through it, you should see a setting with the words "Sleep Off" appear onscreen. If you leave it there, the sleep setting should cancel, allowing you to turn the set off when you like. If you miss it, just keep pushing the "Sleep" button. It will continue to cycle through the options until "Sleep Off" appears once again.
  3. Step 3 Access the timer function to shut off the timer by pressing the "Menu" button, then cycling through the onscreen options until you reach the "Applications" setting. Press it, and then cycle through to the "Clock/Timers" option.
  4. Step 4 Highlight the "Timer 1" setting and press the "+" button. If it's showing a given time, you'll need to deactivate it. Use the up and down arrows and move through the possible options until you come to the "Off" setting. Leave it there; that should shut the timer off.
  5. Step 5 Repeat the process with the "Timer 2" setting, a little further down the "Clock/Timers" menu. Set it to the "Off" position just as you did with the "Timer 1" setting.
  6. Step 6 Press the "Menu" button when you are done to exit the menu and return to the screen. You should be able to view the Sony TV as normal with no danger of it turning off.
good luck
Aug 08, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I pressed the sleep button by accident and the pic and sound went off and the stand by/timer red light started blinking. what does it mean?
Depends on how many times it blinks,just count the blinks Example: if it blink 2 times then pauses and blink 5 times then the code would be 25 and so on
Once you have this code,please post it.
Jul 30, 2009 | Sony KV-32S40 32" TV
Sleep timer?
Sleep Timer option is available in remote only.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Setting tv to channel 3
When the led blinks twice it is telling you that the remote accepts the code, but that does not mean the tv accepts the code. If the tv does not power on after programming the new code then you must try the next code in the sequence, until you find one that powers on or off the tv.
Aug 25, 2007 | Radio Shack (15-2147) Remote Control
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
198 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
