Searching for wiring diagram
Need wiring diagram for Apelco FishFinder combo 6760. I dont have any connectors for back of main unit but wish to find what each pin is connected to... plz help. dazed & confused !!!
    Genius:
  • 1,224 Answers
Http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=420817e4b66b5093026515350edf12d2&q=Raymarine+Apelco+6760
heres the link to download manual it will have wireing diagram in it for you also i will be uploading the manual to fixya
Posted on May 21, 2008
Hello! I have NAVMAN 4150sx fishfinder and I need wiring diagram for that fishfinder. Erkki
Here is the link to the owners manual.It has a copy of a wiring diagram.Not sure if it is the one you are looking for but maybe someone else may be able to use it if not. Hope this helps you with your project
Good Luck
http://www.navmanmarine.net/upload/marine/internet_manuals/eol/4100_4150_eng_web.pdf
Dec 09, 2014 | Fishing
Where is the radio speed sensor wire on Hyundai/Infinity model 96560-0A500 radio?
sounds like either a call to dealer service to try for an answer or a car audio store for some help..good luck..
Dec 08, 2013 | 2009 Hyundai Sonata
Connections problem
Question: What are the extra wires used for on the power cable for my fishfinder?
I found this on the carmin website under questions and answers. I think your cable is ok to use according to this.
--> Answer: Not all of the wires in the harness are required for use. To connect the unit to the power source, only the black & red wires are required (black to ground, red to positive). Here are descriptions of the other wires in the harness:
  • The Blue wire is used for a NMEA data out connection to another NMEA compatible device. The fish finder outputs NMEA 0183 version 3.01. The receiving device must be compatible with this format and looking for the NEMA sentences DPT, DBT, MTM, or VHW.
  • The Brown wire is used for a NMEA data in connection to receive data from another NMEA compatible device.
  • The Yellow wire is used to connect to an external buzzer or alarm to alert you to any alarms which have been set to sound on the device. The Yellow GARMIN wire connects to the negative end of the external alarm. The positive return on the alarm will connect to the red positive wire of GARMIN.
  • The green, white, and any other colors present have no connection purpose related to your fishfinder. The 18 Pin connector wiring harness is used by several other devices which utilize these wires.
If the device is only being connected to power & do not require a NMEA interface, PC connection, or external alarm support, only the red & black wires are required.
Jul 05, 2012 | Garmin Fishfinder 90
Main wiring loom lost for my system. it has a 6 pin plastic connector. what do each of the 6 pins do ?? i have a connector but dont want to blow it up.. thanks Richard
You've failed to tell me the GPS device name/make/model. I can't find you a pinout diagram without this information.
However, Provided you connect the six wires in the same fashion as the old one, you'll be just fine. Chances of anything blowing up are very slight (unless you stash your plastic explosives in your gps unit) The six cables are nothing more than power, ground, and data.
May 09, 2011 | GPS
Missing power supply. First, thanks to fredtmccoyjr for the boot fix. the BIOS update from A06 to A09 actually allows me to enable boot from harddisk in the settings, instead of settign a useless tick on...
It was the 1996 to 2000 time frame, that Dell was proprietary with the 20-pin ATX main power cable, and the matching connector on the mobo. (MOtherBOard).
Standard 20-pin ATX main power cable, and it's corresponding connector should work, then add the 4 power wires that are missing, in a separate connector.
To expound:
View this standard 20-pin ATX main power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
The power wires should be in the same place as your P3 units.
(Match the color codes.
Use the lock tab on the 20-pin ATX main power cable connector, to base where the pins are.
Pins 1 though 20. Match the color code of the wires to the pins, and use the chart to compare)
Here is a view of a standard 24-pin ATX main power cable, and it's respective connector, so you can see what power wires are missing, from the 20-pin ATX main power cable connector, that are present in the 24-pin ATX main power cable connector.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Note the missing power wires, and what pins they line up with.
The P4, or also stated as the 4-pin ATX +12 Volt power cable, uses two Yellow (12 Volt) wires, and two Black wires, (Ground)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Since you don't have the male connector, be sure to orient in your mind where the Yellow (12 Volt) wires go, and the Black (Ground) wires go, by looking at the lock tab on the side of the female connector, on the motherboard, and comparing it to the photo.
Transfer this info, to the P4 connector you are going to make.
Where to get the power wires you need? Connect to any extra 4-pin Peripheral power cable wires, or splice off of ones that are in use, is one suggestion.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
The links given are near the middle of the page. Scroll back to the top. Left-click on any power cable connector, that you wish more information on.
More info,
http://en.wikipedia.org/wiki/Computer_power_supply
Scroll to the bottom of the page, and look at the chart under the heading -
24-pin ATX12V 2.x power supply connector
(20-pin omits the last four: 11, 12, 23, and 24)
One more link,
http://www.smpspowersupply.com/connectors-pinouts.html
Lastly Dell Support > Optiplex GX260 > Service Manual,
http://support.dell.com/support/edocs/systems/opgx260/en/sm/index.htm
Just in case it's of any use.
Have questions regarding what I have stated, or need more clarification of anything I have stated, simply post in a Comment.
Jul 06, 2010 | Dell OptiPlex GX260 PC Desktop
Hi I have an Apelco 530 fishfinder/gps and need a through hull transducer kit. Apelco were taken out by Raymarine who advised me to contact Airmar who made the transducers. So far no answer but their...
Embedded
I was looking to see if I could find a replacement for the display and was able to confirm that the transducer is a single beam 120khz unit so I doubt that you've find a replacement for it ..as is .
The Airmar C-49 is the proper number for the connection line but like me I think your going to have to think about a whole new unit and or system . Been there already.
Best of luck.
Sir Isaac
Jun 22, 2009 | Raymarine Boating
Raytheon --Apelco 365--fishfinder
For the information of future searchers, I add an OEM type repair that has just worked for me.
Go to the dollar store and pick up any audio lead that has a single narrow pin in the centre. Cut the plastic where the cable enters the plug to expose the end of the pin and wire connection. unsolder the plug and at the same time using the heat from the soldering iron, withdraw the pin from the plastic that is holding it in place. Now you have an unsoldered pin all on its own.
Remove the back from the Apelco 365 and unsolder the wire on the broken pin, (mine was just a push fit). Touch the broken pin with the soldering iron and withdraw it. Insert the new pin, heating it a little with the soldering iron. From the outside of the back case, check the alignment of the pin, making small alterations using a bit of heat. Once satisfied, apply a little dab of crazy glue to fill any gaps around the pin.
Job done. In future use a little Vaseline Petrolem Jelly on the female plug and make sure the plug is square to the back when you insert it, and lined up with the notch at the top.
Oct 15, 2008 | Boating
Apelco 365 fishfinder. Broken pin on power connector
i did the same damn thing and am amazed this question is on the net. i bought a new system but plan on taking it back. the 365 was a pretty nice model and i'm just going to splice it straight to the power supply. but i was lucky, the two pin connector is the damaged one so drilling it out and splicing it SHOULD be easy. well see. at this point i have nothing to lose.
hope this helps.
Jul 27, 2008 | Raymarine A65 Combo GPS...
Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Jun 17, 2008 | Coleman Mach III Air Conditioner
Computers & Internet Logo
330 people viewed this question
David Payne
David Payne
