Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
My Bosch washing machine door won't open... HELP!!!
My Bosch (Next) Washing machine door won't open... HELP!!! I'm leaving on vacation and I need my clothes. It all started when I wanted to add additional clothes and I pushed the on/off button... nothing then I switched it off and still nothing... PLEASE HELP ME. JOANNA
  • Anonymous May 24, 2008
    same problem with my bosch axxix+ washing machine. door will not open. i checked the child lock and it is set to off, i did an emergency lock release but that did not work either. i hit the circuit breaker for over 20 minutes as suggested by the bosch hotline, but that did nothing. i can get service at $69 to come and give me a diagnosis and $110 an hour for the work.
barkencoa
  • 3463 Answers
SOURCE: bosch wwf1201 won't drain.
Probably a blocked filter that needs cleaning.
You should find this located at the bottom front right of washer behind drop down flap/cover.
Unscrew anti-clockwise to remove and clean.
Posted on Mar 31, 2010
  • 6277 Answers
SOURCE: I have a Bosch maxx
I suspect that there is water still left inside as the drain pump has been unable to complete its task so they are being spun in water!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 19, 2011
  • 118 Answers
SOURCE: My Bosch washing machine is leaving sludge like
Make sure the draw is 100% clean inside the draw compartment to if the draw is all clean next thing to cheak is the rubber door seal make sure it is clean all the way round next thing to cheak is the pump at the front of the machine pull down the cover and undo the the pump cover by tuning anti clock wise water will come out when you cheaked it is 100%clean put it back together if you get stuck read manual if all toughs things are clean or bean cleaned. do a 90 again with washer cleaning detergent with you can buy at the super market hope this helped.
Posted on Sep 02, 2009
Testimonial: "Great advice. I cleaned around the rubber door seal with a thin long handled brush. Worked a treat. No more stains on my laundry. Thank you! X"
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
barkencoa
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
I have a Bosch Maxx WFL 1662 washing machine. It does not stop washing and go over to the rinses sickle.Where do i start looking for the problem?
Hi Eric, There's two links below... 1st link is Bosch Washing Machine Error Fault Codes and the 2nd link is worth reading, The master reset is only part of the trouble shooting, I hope these help.
To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components. (This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
How To Fix Washing Machine That Is Not Spinning or Draining
Apr 02, 2016 | Bosch Washing Machines
Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Nov 03, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Nexxt 300 has error code E-13 and the door is locked. turned on/off, unplugged, removed the drain hose to see if it is blocked, but ok. but still won't unlock. Is there someway to unlock the...
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
May 18, 2011 | Bosch Washing Machines
My Bosch washing machine door will not open and it keeps flashing " check door" however there is no child lock on and also no clothes stuck in door. Also I have detergent and bleach in the tray and do...
Check out this link to the Bosch service manual for more information regarding your machine: http://www.bshextranet.com/files/techtoolbox/WFMC1001UC_9000151579.pdf
This may offer some help...if this is of no use then us the associated info to contact the mfg directly for more info. Thanks, Randy
Jan 18, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 800 Washer Distugsting Smell
USING NON BIOLOGICAL DETERGENTS AND LOW TEMP WASHES WILL EVENTUALLY LEAVE GUNK IN DRUM AND AROUND DOOR SEAL TRY USING BIO DETERGENT HOTTER COTTON WASHES AND THE OCCASIONAL 90 DEGREE WASH
Aug 08, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
A mold smell from my washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Dec 28, 2008 | Bosch Classixx WFO 2466 Front Load Washer
My Bosch WFF 2000 washing machine goes through its cycle and then leaves the on/off button lit, the door button lit and the pre-wash button flashing; also the door will not open until you turn all the...
The problem turned out to be foreign objects in the pump that stopped the machine from draining; the solution is simply to open up the pump and remove the objects!
Sep 09, 2008 | Bosch Washing Machines
Bosch Axxis Front Load Washer
This video will show you how to change a door seal on this Bosch GLTF2940ES front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Aug 20, 2007 | Frigidaire GLTF2940ES Front Load Washer
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
5,824 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
