Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite he4t
I have a f33 error code,what does this mean?
  • lamdimar93 Apr 28, 2009
    When I use the prewash option, I will get the F33 error code once the washer starts on it's wash cycle. If I turn it off and start the washer again and don't push the prewash button, it runs just fine.
  • 725 Answers
Really need the whole model # ?
1 pressure switch
2 flowmeter
3 CCU
4 hose
he F33 means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch, the flowmeter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Posted on May 20, 2008
We just had our HE 4t serviced for a f 33 error. Apparently, the drum was rubbing against an air hose that created a small pinhole, which caused the drum to keep filling with water. Luckily, our tech knew what to look for! The cost was about $120 to repair
Posted on Oct 12, 2008
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: error code f33 on an he4t
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 19, 2010
Kenmore elite he4t f33
The F33 code can indicate a bad pump or a problem with the wiring either at the pump or the CCU (central control unit), or the wiring harness itself. Before you replaced the pump, did you test the resistance in the wiring harness?
Unplug the washer and use an Ohmeter (VOM) to test. See http://media.fotki.com/1_p,wtftddqbdtwbdkrxgtqsskgwtqkq,vi/tgdkbwkswxfddbwsbdbxtbgtgwftb/1/1303472/5961857/image49983img-or.gif for the schematics of the wiring for the pump on the CCU. To access the CCU, you need to remove a few screws on the back of the top panel. You remove the lower service panel on the front of the washer to access the pump. The wiring should read 12.3 ohms at the CCU. If you get a reading of infinity (open), check the pump. If the leads to the pump motor give a resistance of 12.3 ohms, then the wiring harness should probably be replaced. If the circuit to the pump is fine and the error persists, then the CCU is faulty and needs to be replaced.
I hope this helps. If you add a comment with the specific model of your washer, I may be able to give additional suggestions.
Dec 23, 2012 | Kenmore Washing Machines
Getting a f33 error on front load kenmore HE4t already changed the pressure switch and flow meter but still get f33 error
Jan 22, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Error code f33 on an he4t
Oct 11, 2009 | Kenmore Washing Machines
Kenmore elite he3t model 4596640 year 2005 f33 code
May 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Getting f an h error code
ok do you have flood stop hoses on your machine. if you do take them off and get a bucket turn the hoses back on and fill the bucket if no water comes out of 1 of the hoses your problem is the hose. the error fh means fill hose.
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
F Code for the Kenmore Elite he4t Front Load Washer (3 years old)
Hi! ricksmith
What is the first three digits of the model number.
The he4t I have reference to does not have a "F" code error. Most of the codes are two digit, PF, F1 to F9 etc.
You could try: Pressing Pause/Cancel two times to clear code. As well as unplug for 20 seconds. Do you have power fluctuations in your area.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite error code
possible electronics failure. my HE4t has completly gone dead at the control panel after displaying error codes. A class action law suite is in the works on the HE3t HE4t machines.
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he4t
May 20, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
1,019 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
