Question about GE Dryers
Ihave a GE DryerModel No DBXR463EGIWW The Start Switch stays on all the time. I checked the switch for a part number and all I could find was 0720,,assembled in Mexico.
    Genius:
  • 1,073 Answers
Part number is we04x0881 for the start switch
Posted on May 20, 2008
Why want this dryer stay on ?
you have a bad belt switch,if the dryer stays running while you hold the start button on and stops when you release the button its the belt switch part WD21X10261 i've seen this a few times,go here and look at part 803 this is the bad part.
www.searspartsdirect.com/model-number/DPXR473EW0WW/0432/0151200.html
Oct 03, 2017 | GE Dryers
Why doesn't the dryer stay running when I let go of the start switch?
Hi, There is only one reason I can see the dryer stops after you let off on the start switch is the motor because GE motors has start switches either built inside the motor which is non removable or built outside the motor which can be replaced .
Its called a motor start switch and the way to locate it is to remove the front panel on the dryer and remove the drum and belt and then write down the motor model number and look at all the wires that go into the motor which is your motor start switch that is held in by two screws but before you remove it don't forget to copy the wire down on piece of paper of how you remove them .
If you don't see a black switch to the motor then its built in and the motor needs to be replaced.
Oct 23, 2014 | GE DWSR483EBWW Electric Dryer
My GE Spacemaker dryer will run but the washer will not start in any cycle (stacked unit)
It looks serious problem. You should go to your nearest repairer to solve the problems if you don't want to stay without your washer.
Mar 13, 2014 | GE Spacemaker Washer and Dryer Electric...
Light "Burner On" stays on all the time on my electric stove GE model JBS27WH2WW
I have a GE Range Model JBS27W H2WW and the serial# XXXXX that I was cooking on and the back burner starting throwing out sparks and blew a hole in the coil and the drip pan. Now the light Burner on is staying on and I switched the 8 inch burner in the front with this 8 inch burner and still cannot get it to work.
Dec 19, 2013 | Cooktops
Problem with my GE dryer mod: DBSR453EB1CC. Tried turning it on, and would stay on. As soon as you let the switch go. It shuts off. While its on the tumbler doesn't move. I would appreciate any advice....
That sounds very typical of a broken belt. GE dryers use a belt switch that will cause exactly as your describing...the motor will run as long as holding the start switch and as soon as you release it the motor will stop if the belt switch is not satisfied that the belt is in place...so it again sound very much like the belt is broken.
The part number for the belt is WE12M29 it could be purchased at your local appliance parts store or online at;
apdepot.com
partselect.com
apwagner.com
repairclinic.com
Sep 23, 2011 | GE Dryers
When I turn my TV on, it clicks on and off 5 times then stays off
first check a switch contacts, that switch has two make contacts in side it. if the switch is okay, then check a power supply dry joints on it.
or a dry joint on the line out put transistor, or a line transformer legs.
Apr 30, 2009 | RCA F27450 27" TV
Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Nov 25, 2008 | GE Dryers
Starts, but won't stay running
just check the start switch might be defective change a new one.
hope it may help
regards
Sep 08, 2008 | GE DBSR453EBWW Electric Dryer
Ge dryer wont stay running
start switch is bad,it is stuck inside,get the model number inside dryer door or on top panel,call local appliance parts store to get new part,only a few bucs,replace and you should be allright,let me know-mike
Jun 15, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
83 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
