Question about Dell Dimension 4600 PC Desktop
I reformatted my 4600 and my USB arent working.. No troubles showing in the device manager. Computer doesnt recognize any new device when I plug into the USB. Trying to install my printer, but doesnt see it so I tried another usb device but doesnt see that either. I also tried this in all USB on machine. What to do now?
  • gchuzi Dec 26, 2008
    I have the same issue, but I installed the network and desktop system drivers first and now the chipset driver won't install (hangs at 90%).
    What now?
    GChuzi
  • 3,940 Answers
When you reinstalled XP on your Dimension 4600, did you install the drivers in this order. USB is part of the chipset and the driver will need to be loaded for USB to function normally.
Chipset Utility:
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R58201&SystemID=DIM_P4_4600&servicetag=&os=WW1&osl=en&deviceid=3268&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=27&fileid=70069
Video Driver
Audio Driver
NIC Driver
All available here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=DIM_P4_4600
Posted on May 20, 2008
I can't get my usb devices to work on my dell 4600 series pc. It won't reconise anything I try to plug in to the usb ports.
Try deleting your usb drivers.
Right-click My Computer
Manage
Device Manager
USB Controllers
Delete (Generic USB Hub)
Restart computer
(Windows will auto-install the drivers, on reboot)
Plug your device back in, and see i've it works.
ALSO PLEASE RATE MY SOLUTION
Jun 21, 2011 | Dell Dimension 4600 PC Desktop
Why doesnt it show on computer when i plug it in
What kind of flash drive and computer are u working with? Let me know and I may be able to give u a more accurate answer. Try inserting another device in that USB port and check to see if ur computer is recognizing it in your device manager. Click on Start Tab then Go To Settings , Control Panel Then Click on System Icon , Then Click on the Hardware Tab and Click on Device Manager, scroll down to see if there are any yellow question marks or flags? Leave that Device manager window open and try to re insert your flash drive again and see what response u get?
Jun 30, 2010 | SimpleTech SimpleDrive 160 GB External USB...
Computer cannot recognize the drive now, after months of use.
Check the Adminstrative Tools status.If it says unallocated,it needs to be either reformatted or recovered.
Sep 10, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Cannot connect to computer
FIRST OF ALL, NEVER EVER PLUG IT INTO THE COMPUTER WHILE ITS ON. ALWAYS TURN THE PHONE OFF BEFORE HAND. AS FAR AS YOUR COMPUTER NOT RECOGNIZING THE USB CABLE, IT MAY ACTUALLY BE YOUR COMPUTER. AFTER ALL IF IT WAS THE CABLE, YOUR PHONE WOULDN'T CHARGE SINCE IT IS THE SAME CABLE FOR CHARGING AND USB CONNECTIONS. MY COMPUTER HAS HAD TROUBLE SEVERAL TIMES WHEN PLUGGING IN NEW OR DIFFERENT DEVICES INTO THE PORT. TO CHECK THE USB PORT ON YOUR COMPUTER.... GO TO CONTROL PANEL, THEN DEVICE MANAGER. DOUBLE CLICK UNIVERSAL SERIAL BUS CONTROLLERS. IF ANY OF THEM ARENT WORKING PROPERLY THERE WILL BE A YELLOW TRIANGLE WITH AN EXCLAMTION POINT BESIDE THE UNFUNCTIONING USB. IF IT IS NOT FUNCTIONING YOU WILL HAVE TO UPDATE THE DRIVER. IF YOUR PORTS, DRIVERS ETC DONT SHOW THE YELLOW TRIANGLE, THEY ARE WORKING. TRY PLUGGING THE PHONE INTO A DIFFERENT PORT UNTIL YOU FIND ONE THAT WILL ACCEPT IT. I HAVE A LAPTOP AND MY PHONE ISNT RECOGNIZED IN THE SAME USB PORT (ON THE RIGHT SIDE OF THE COMPUTER) THAT I USE FOR MY PRINTER. I USE A DIFFERENT PORT FOR MY CELL PHONE. IF YOUR COMPUTER IS OLDER , THE USB PORT MAY NOT BE HIGH SPEED. OLDER COMPUTERS HAVE USB PORTS WITH A SPEED OF 1x OR A MIX OF PORTS WITH 1x AND 2.O (2.0 IS HIGHSPEED 1x IS NOT). I HOPE THIS HELPS!!!
Jun 23, 2009 | Dual Electronics CECT P168 Cellular Phone
My noteoook got the problem with port usb
Since you have these many problems with your laptop, Firstly try to reformat the system and reinstall all the neccessary drivers. Many times reformatting works well as your OS might malfunction when you have virus or malwares in your laptop.
OTHER SOLUTIONS
a. for USB:
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
  2. Expand Universal Serial Bus controllers.
  3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
  4. Click the Power Management tab.
  5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
  6. Repeat steps 3 through 6 for each USB Root Hub in the list.
  7. On the Action menu, click Scan for hardware changes.
    Windows XP recognizes the new device.
  8. Close the Device Manager window.
b. SD CARD
Your 1GB kingston card might have virus. use a card reader and reformat the card for future use.
c. Uninstall and reinstall the driver of your finger scanner.
Hope this helps,
~regards,
Jegan
Jun 01, 2009 | Lenovo 3000 N100 Notebook
Jazz JDC5 I Dont know how to use the instructions arent clear
Hey Jazz_JDC5_Digital_Camera_DRIVER setup [URL=http://hotfile.com/dl/25964598/c5989b0/Jazz_JDC5_Digital_Camera_DRIVER.rar.html]http://hotfile.com/dl/25964598/c5989b0/Jazz_JDC5_Digital_Camera_DRIVER.rar.html[/URL]
Mar 08, 2009 | Jazz JDC5 Digital Camera
Cannot reformat my USB 4gb kingston
the reason is ur pen drive has lost its capacity to store datas. u cant use that pen drive anymore and it cannot be formatted also. try for a new pen drive
Jan 18, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
USB problem with Dell Dim. 4600
1.have you use other usb device also same ?????? try plug in rear port usb also same????
2.try to use you original dell cd to preloaded OS. to see usb can recognizing.if still can't may be you usb port faulty need to change motherborad
Jan 02, 2009 | Dell Dimension 4600 PC Desktop
No usb
If your USB ports are installed correctly and enabled in BIOS, you will see Universal Bus Controller list in the the Device Manager. Double-click your USB in the Device Manager and a dialog box will appear. Click on the driver tab and update the driver. To get to Device Manager right-click on My Computer>click on Hardware>Device Manager. If your computer has a built-in USB device and does not detect the device through the Device Manager, confirm that the USB is enabled in the computers BIOS and that the BIOS supprts USB devices.
Dec 29, 2008 | HP Compaq nc6000 Notebook
Reformatted drive and now it won't work on second computer!
go to my computer>properties>device manager and scan for new hardware changes after connecting the device to your system...
if the device doesnt show up..try to install the usb driver of the particular make..
thankyou
Aug 31, 2008 | Western Digital My Book Essential Edition...
Dell Dimension 4600 PC Desktop Logo
200 people viewed this question
Alun Cox
