Question about Amana NAV8800E Top Load Washer
Amana NAV8800AWW making noise while running and spining. It used to shake the floor while spining. But lately machine is making noise but not as shaky as it use to be. Thanks for your help.
  • aaj_1 Jul 01, 2008
    Hi Dave.
    Thanks for the help..Anyway when I open the washer I did not see any loose part. but water leak inside. I think it some kind of seal that is leak into a bearing a making the noise. I asks a local guy for fixing it, he is asking for $250.00 for the repair. I am debating to buy a new one or repair it. Any suggestion?
    Thanks,
    AJ
  • Anonymous Jul 13, 2008
    Had the same problem and found the seal under the inner tub was leaking. The noise is coming from the bearing in the bottom of the outter tub. This bearing went out because of the leaking water.
  • 525 Answers
Spin Shake is usually contributed to a weak floor support condition. Also, carpeting under the leveling legs can cause a "spongey" effect, which can produce the shakes. Prolonged shaking can cause parts to loosen and make noise.Firstly, we must determine what loosened up from all the shaking.
Remove the front panel by removing the 2-5/16" screws located at the bottom front. Pull out at the bottom to release the top retainer clips, and set aside.
Warning! Never reach inside the machine while it is in operation!
Investigate the cause of the noise by setting the washer to spin, and turn on. Inspect all moving parts for possible wear or breakage. Next, stop the machine and inspect for loose or worn suspension parts, nuts, bolts, struts, hoses banging the cabinet, etc. A protective motor cover can cause noise, or a belt slapping the base mount. Once you have conquered your noise issue, then we will have to eliminate the shakes, provided, what you repaired wasn't the cause...and usually isn't.
Carpeting under the leveling legs should be removed or cut away.
If other items in and around the laundry room shake, then you will need to add support to your floor joists. Shim the floor from under the house while the washer is spinning for best results.
Your installation instruction manual should tell how level the washer properly, after you have added support to your floor.
Good Luck! Post me back if can be of more assistance.
Dave E. (Illeagle)
Posted on Jun 06, 2008
My lg washer shake s alot when it is spining and makes a loud noise please can you help
The washer needs to sit on a solid foundation for this to work. When the washer is spinning a load of clothes, push the corner of the washer till the noise or vibration quiets down. When it does quiet down, adjust the leg below to reduce the noise.
Good luck
May 26, 2011 | LG WM-2277HW Front Load Washer
Excessive shaking on spining , washer moves a round on the floor I have leveled it rght on the nose.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 18, 2011 | Kenmore 44042 Front Load Washer
I n the spine cycle the washer makes a loud noise and shakes.I found a dime under the tube between the rim and door gasket.
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 22, 2010 | LG WM2016C
My brand new amana washer shakes violently when spinning
try adjusting the feet on the bottom of the washer the floor may not be level to adjust the legs turn them with a wrench or if the lock nuts are not tight turn the legs clockwise as you look at the front of the machine till all four feet are sung on all 4 corners. This is the most common problem. hope this helps and thanks for using fix-ya
Feb 15, 2010 | Washing Machines
Washer shakes when spining. More on heavier loads.
shaking is generally due to inadequate floor structure under machine; i.e. plywood floor. in addition, if the washer is on a "pedistal" it will make matters worse; as the center of gravity is away from the floor. in rare cases, one of the drum "struts" can fall apart; and, cause excessive shaking. if you broke the locknut on one of the legs, unscrew the leg, and bring it to the hardware store for a replacement nut.
Feb 15, 2010 | LG WM2487H Front Load Washer
My amana washer makes a whril noise when it spines.
UNFORTUNATLY IT IS PROBABLE A SPIN BEARING THAT IS MAKING THE NOISE. THIS IS USUALLY CAUSED BY A LITTLE WATER LEAKING FROM THE CENTER SEAL ONTO IT. IT IS VERY EXPENSIVE TO FIXED AND VERY TIME CONSUMING, PLUS YOU WILL NEED SPECIAL TOOLS DESIGNED FOR THE JOB
Aug 11, 2009 | Washing Machines
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Amana NAV8800E Top Load Washer Logo
395 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
