Question about Whirlpool LGV4634JQ Gas Dryer
Whirlpool lgr4634eqo makes a buzzing noise when trying to start
Dryer makes a buzzing when trying to start. what should i checkfirst
  • k11lang May 20, 2008
    how do I know for sure
    How do I fix it
  • Whirlpool Master
  • 2,992 Answers
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push on the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Posted on Mar 01, 2015
  • 145 Answers
Try holding the door switch lever in and turning the drum hard by hand. It sounds like you have a start switch out in the motor.
Posted on May 20, 2008
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My dryer is not working and only making a buzzing noise when i press the start button
is the buzz more like a growl? if so, you probably have a bad motor. if it is truly a buzz, then try turing your timer to a different cycle. if the problem continues, replace the timer
Jan 22, 2011 | Whirlpool LER4634J Electric Dryer
I tried to start the dryer (whirlpool LE5700XK or the LG5701XK, not sure which) and when I hit the start button there was a loud buzzing noise, but no start. I turned the dial to the off position, and then...
Could be a couple things, depending on the buzz you are getting, if it's a buzz from the board like an alarm, it could be a door switch, if it's an electric sounding humming buzz it could be something stuck in your blower wheel like a sock
Jun 24, 2017 | Whirlpool Dryers
Dryer has started to make a loud sqealing when it starts and gets up to speed, the kind of sound a loose fan belt makes on a car, and now just makes a buzzing sound when the button is pushed but dosen't...
If you push the start button and you here a buzzing sound, This sounds like the motor is bad.
Somthing you can try and this might not work. but open the dryer door and turn the drum a littel bit then close the door and try to start it. If it starts running again then you have hit a bad spot on the motor.
If it just still just makes the buzzing noise then the motor is most likley bad.
Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer makes a buzz noise when push
pull motor switch out(the one with wires go in motor) best use compressed air.... lint is stopping lever... this all happens after you turn breakers off...hi hi
Aug 27, 2009 | Whirlpool ET8CHEXSQ Dryer
Old GE dryer DDE8200GDLWH
Sometimes when the windings in the motor start to go bad it has to overcome more load at the start up therefore drawing more amps and after to long the dryer will no longer start, time for a new dryer
May 03, 2009 | Whirlpool GEW9250 Electric Dryer
Gas dryer lgr4634eqo GAS
check the thermal fuse located at the back of the dryer for continuity and let me know how you make out
Sep 13, 2007 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool LGV4634JQ Gas Dryer Logo
306 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
