Question about Gateway Computers & Internet
The screen comes up and says Windows was not shut down properly, and to start in Normal, safe mode, etc. to choose one of them. Nothing happens and it keeps trying to start. So once I hit f11 to recover, a screen comes up and says "system Restore - format and recover: all files, including data files, on the user partition will be lost and the original factory-shipped files will be recovered to the user partition. Do you want to continue? ok box is the only what do I do here, do i say "ok"? What do I loose? Was is the user partition?
  • 3,940 Answers
If you Click OK on the system restore, the system will be re-imaged from a hidden partition on the hard drive and will be restored to the way the system was when it came out of the box. Anything you saved or stored on the hard drive, (Pictures, files, games email, resume etc) will all be gone.
Because the system will not boot into the normal mode, it is assumed that the current Windows installation is at a minimum damaged. The damage could be caused by:
  1. Virus/spyware
  2. Hard drive failure
  3. various unkown issues
If you are wanting to save data off this hard drive, just power it off at the system restore screen.
If you can, run diagnostics on the hard drive (Dell has F12 at boot to access diagnostics) If the hard drive fails, your data recovery options are limited.
Data recovery is expensive, so you have to weigh the value of the data versus the cost of getting it back.
Posted on May 20, 2008
My laptop was a gift xmas 1 year ago. when i turn it on there is a black screen and then there is this message ; it say sorry for this problen windows didn't start normally. then it gives me 4 or 5 choices...
#2 "safe mode with networking" will only work if you were attached to a local network and configured to boot from it. This is not the normal configuration for most users. The network they are referring to is NOT the internet.
You should try #1 and after it is booted try a restart [Start], [Shut down], then use the pull-down to select Restart. If once it
Feb 25, 2011 | Computers & Internet
Hello, I have a compaq evo n110, and it was working ok then froze and restarted, started working again then did it again. now it comes up saying windows was not shut down properly and asks the usual...
There are many different things that could cause the issue you describe.
About how old is this computer? If it's between 3-5 years old, you may want to consider purchasing a new one.
Has anything changed recently? Did you install software or other updates that may have caused this issue?
When it goes to the screen that lets you choose Safe Mode, etc., do you have an option that reads "Last known good settings?" If so, choose that option to start the computer with.
May 19, 2017 | Compaq Evo N110 Notebook
My presario m2000 will turn on but comes up with a screen
This is happening because you're not turning the computer off properly, make sure everytime you turn your computer off you go to
Start menu
Shut down.
You need to select start windows normally.
Safe mode will help you with some otherthings
just make sure of turning the pc off properly ;)
Apr 27, 2010 | Compaq Presario M2000 Notebook
Wont open home page
Choose safe mode. If you can't even get into that then you have a serious problem. You'll have to boot with a CD and repair the installation of Windows.
Nov 09, 2009 | Acer TravelMate C110 Tablet PC
Hello I wonder if you can help. When we switch
Had a similar problem like this several times. Try choosing safe mode. Safe mode will load the required drivers. After safe mode finishes the loading process, restart your computer and choose to start windows normally. The problem you mention usually happens when the computer is turned off without using normal shut down procedures. Also happens when you have a sudden power outage.
Oct 24, 2009 | Computers & Internet
I cannot logon to my PC
Start your PC in safe mode, to do this repeatedly tap the F8 key as soon as you turn the power on. This will then bring up an "options" screen listing boot in safe mode, safe mode with network support etc. Just use safe mode. If it goes directly to windows instead - shut it off and try again til u get the safe mode screen. The arrow keys control the selection to choose.When it starts in safe mode a black screen will usually appear with a bunch of writing, this is normal, after that it may "hang" for as long as 5 minutes, before coming up with a login screen. Sometimes hitting enter or escape will bring up the login screen faster. When you have a login screen, login and disable the updates using the software control options for the software that is trying to update. You might also go to control panel, administrator options, then services and disable automatic updates temporarily. When your pc starts in safe mode - it starts with minimal drivers and does not run updates- this allows you to change settings. You can then reboot normally and it should start properly without updating before starting.
Aug 29, 2009 | Acer Aspire AM1610-U1201A PC Desktop
Can't log on
what i can suggest you is to reformat/do a recovery..nothing else....dont waste your time..because you cant load in windows right? its commin only with blue screen...when you select safemode or etc..nothing happen...try with my suggestion..if you have some important files you can do a backup by removing the hdd and put into usb adaptor and plug in any computer that can do a backup....i hope you appreciate it
Jan 05, 2009 | HP Pavilion ze4933US Notebook
Cannot start Sony VAIO PCG-5J2L /Goes to black screen only
During start-up the computer will go to a black screen for awhile and then the pointer arrow will show alone, and then the system will come up.
If you think it's a hibernation problem, pull the ac plug and battery out for about 1 hour and then plug back in.
If this didn't work, then try the F8 Key and choose "Last Know Good Configuration".
Nov 30, 2008 | Sony VAIO PCG-K23 Notebook
Computers & Internet Logo
78 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
