Whirlpool GEW9250 Electric Dryer Logo
Posted on Sep 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A red light is on that says"control locked" and the dryer won't work at all. Can not find a way to unlock it? [email protected]
Anonymous
Level 3:
President:
  • Master 1,796 Answers
  • Posted on Sep 21, 2010
Anonymous
Master
Level 3:
President:
Answers
1796
Questions
0
Helped
840518
Points
5971
Hi!!
Try unplugging the unit from the wall outlet, wait for a couple of minutes and plug unit back up. This is supposed to reset the unit.
Good Luck!!
Whirlpool duet dreyer control lock On --can't program dreyer
try unplugging for a couple of minutes and it should reset to factory settings.
tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
Control locked light is on, washer won't work
If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
Whirlpool dryer duet... the control lock light is on and the dryer won't work
this is the car and truck section - you may want to repost this in the dryer section
15helpful
2answers
Whirlpool duet washer dryer, Dryer is stuck on control lock
look to the far right buttons labled control lock, hold it in for 3-5 secs, to unlock
The controled locked light is on and won let us do anything..What does that mean? Can it be fixed?
Very simple. There is a button an the panel that says Control Lock on it. Press and hold it in for 5 - 10 seconds. It should unlock. thanks Dave www.washermd.com
Dryer won;t work
Remove the top cover and take a hair-dryer to the PC boards on the back of the main control panel.. (3 screws take the top cover off from the back) Mine has done it a total of 5 times now.. what it needs is all new buttons installed.. or a new control panel if this works..
Whilpool washing machine model "Duet ht" fornot load
Press and hold the End Of Cycle Signal button
for 3 seconds to turn this feature off.
Locked light is on, the dryer can be stopped by
Good Luck, hope this FIXED YA
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
