Question about Amana ARB220RCW Bottom Freezer Refrigerator
Refrigerator doesn't cool. Thermostat does not seem to be working.
  • polina919 Aug 23, 2008
    Amana refrigirator buttom freezer part is working, but lower is not. When opening the fridge door, then the cold starts blowing up to the upper portion. last week we tried to defrost the fidge, and the coil had even frst, after we have done that the fridge was working fine for a week. Any ideas?
I had an older model Anama BC21VL. The freezer was working but the refrigerator compartment was not much below room temperature. Cold air should come out of a vent at the top center of the refrigerator comparment, but very little was coming out. When the freezer door was opened, then much more air was flowing. It turns out that a flat food packet had fallen on top of the return airflow vent at the bottom left rear of the refrigerator compartment.
Posted on Aug 11, 2008
    Genius:
  • 1,073 Answers
What is the model number for help
Posted on May 20, 2008
Ge turbo cool fridge doesn't cool.
If your refrigerator is not cooling, the problem could be as simple as a covered vent or something more complicated that requires the help of a service professional.
Is your thermostat set incorrectly? It's possible to accidentally bump the thermostat, so check it and reset, if necessary, to the proper coolness.
If there's ice on the evaporator cover ( typically found on the back wall), it's a sign that the evaporator coils inside could also be covered in ice and frost, indicating a defrost problem. Try unplugging the fridge and defrosting it before calling for help.
Since you are hearing no unusual sounds, the problem could be the start relay, which triggers the compressor. Have a refrigerator repair pro determine if the start relay is the culprit and to replace it if necessary.
For more help identifying the causes and solutions, read Refrigerator not cooling or check out the video below. I hope this helps!
Sep 27, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint Refrigerator constantly runs and doesn't shut off normally.
Sounds like the thermostat is not working that is what tells the compressor it is cold enough shut off.
May 17, 2012 | Hotpoint Refrigerators
The fridge (kenmore) doesn't seem to be cooling but the freezer (on the bottom) seems to be working fine. Help! :((( Single mom
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Refrigerators
Freezer works great but refrigerator. Doesn't get cold its cool but not cold turned thermostat to 33 and ut isn't gettingcold
heatman101
Aug 21, 2011 | Kenmore Side by Side Refrigerator
Freezer is cooling but the refrigerator is not. This model doesn't seem to have a fan
heatman101
Aug 18, 2011 | Refrigerators
Freezer works great but the refrigerator doesn't seem to cool real well.
Please as long as the ref. is running, it should freeze very well. if this is not happening check the following.
1, The setting on the thermostat.
2, Check if you have enough gas in your system.
3. Check if your system is not leaking.
4. Check if your door seals are ok.
May 11, 2011 | Danby (DAR604BLS) Refrigerator
Freezer works, it's cool nolt cold in the refrigerator, fan motor doesn;t seem to be working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 19, 2010 | Roper RT14DKX Top Freezer Refrigerator
Refrigerator freezes food. Thermostat doesn't seem to work.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 21, 2010 | GE PSH25MSSSV Side by Side Refrigerator
Refrigerator seem to not cool to the proper
your problem is in hte freezer area open the panel in your freezer you might need a new heat element or a new thermostat unit... not so bad to do or check...
arik from 911.servicetoday.com
Nov 06, 2009 | Kenmore 53092 / 53094 Side by Side...
Amana ARB220RCW Bottom Freezer Refrigerator Logo
234 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
