Question about SanDisk Sansa m240 MP3 Player
Sandisk sansa clip mp3 player
Dont know what happen but my player just want turn on-help please and when I plug it into my computer its not reconized as a device.
my device when turned or will refuse to boot and it keeps restarting the player comes on but computer does not recognize it to download music
  • flemingo May 23, 2008
    I have not used the player for a while. I just replaced the battery (tried several batteries) but the player is dead. The mic light does not come on nor does anything appear on the screen. I have pushed all buttons with no success. Please help.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 28, 2008
My Sandisk sansa 4GB MP3 player is not being reconized my my windows xp.please tell me how to fix it.
go to my computer icon on the desktop---mouse right click----probertiese---device or system . there you can find a solution to all your external devices problems .
rate please !
Jan 16, 2010 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip 4GB MP3 Player
go to control panel and click on portable media devices note:will not work on windows xp even if you downgrade to classic using a disk
Feb 07, 2009 | SanDisk Sansa Clip MP3 Player
Computer won't reconize my sandisk mp3 player
Hi, just had the same problem after restoring my system.
You must disconnect and update your Windows Media Player to Number 11. My reinstall left me at WMP 9 and it wouldn't recognise my Clip. Go to the Windows website, follow the download instructions, and you should be fine. When you plug in the Sansa Clip or MP3, it should recognise it right away. Hope this helps!
Feb 01, 2009 | SanDisk Sansa Clip MP3 Player
Mp3player
sansa fuzzmp3 player,wont turn on or charge up,what happened? I did nothing to it but put it in my pocket as usual...Help please
Oct 04, 2008 | SanDisk Sansa Clip MP3 Player
Mp3 player not reconize
Put the Clip into hold (left-side switch down!) and press the center button down while connecting the USB cable
Mar 15, 2008 | SanDisk Sansa Clip MP3 Player
Go ahead and do this, in case the DB is corrupted:
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 08, 2008 | SanDisk Sansa e250 MP3 Player
I had a similar experience with my Sansa Clip MP3. It wouldn't come on at all, and when I connected it to my computer, a malfunctioning error came up. After browsing the net, I saw a suggestion to fix the problem.
Simply, you must slide and hold the power button for about 15 seconds. This should reset it.
Try to put it on again and it should work! Goodluck!
Mar 07, 2008 | SanDisk Sansa Clip MP3 Player
My mp3 player doesn't work
My Mp3 dosn't work when i turn it on it says updating and when i put it on the charger it tells me instalzing i don't know what to do please help me.
Nov 27, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
52 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
