Question about Belkin (F5D7231-4) Wireless Router
Xbox I just got a new Belkin N Wireless Router. And i got it to work with my desktop but i cant get it to work wirelessly with my Xbox 360 network adapter. How do I set it up?
The xbox360 network adapter might have been loose. You cannot have a USB cable plugged into the xbox at the same time.
Posted on Jun 11, 2008
Having trouble connecting Xbox live. Have wireless router and wireless Xbox 360 adapter. Figured out where adapter goes. Now I'm stuck.
Is the router already setup and working? Do you have anything else that successfully connects to it "wirelessly", like a laptop or desktop or smartphone? If the answer is yes, here's how to setup the 360 to connect to your router:
1. Turn on the console and navigate to the wireless settings screen. On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
2. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
3. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
4. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead.
5. Save your settings and verify the network is functional. On the Xbox 360, use the "Test Xbox Live Connection" option.
Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
What You Need: Active Xbox Live subscription (to access services)
edited from here: http://compnetworking.about.com/od/wifihomenetworking/ht/xbox2wifirouter.htm
Mar 05, 2011 | D-Link DI-624 Air Plus XtremeG Wireless...
I cant connect multiple xbox 360 consoles to my wireless router, WTF dawg?!
Here is a great tutorial to Connect and troubleshhot your Xbox to a wireless network.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 19, 2011 | Belkin F5D8236-4 Router
Cant connect Xbox 360 to this wireless router
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Jan 15, 2011 | Linksys WRT160N Wireless Router
I try to plug in my belkin 54 wireless usb thing into my xbox 360 and my xbox doesnt even recognize that it is in there and i dont know where to start but i would like to be able to play games online and...
XBOX 360 is alredy wifi enabled you dont have to plug a thing in to it, if you want to configure wireless
All you got to do is turn on your wireless router/access point and try to search for available network in Xbox 360 and upon selectin the network it would ask for wireless key (WEP key cab found on the back or bottom of router) punch in the key and bingo...its done
Your box is ready to be wirelessly connected to internet and play online
alternatively if you dont ahve a wirelss router or you are facing difficulty is seraching wireless router or finding the security key
Connect the router to modem > then connect the router and XBOX with an ethernet cable
It will work
Else you can also try connecting the modem and XBOX with an ethernet or USB cable
(However in all the aboove scenario, please ensure the modem is getting the internet link through the normal RJ11 or phone cable, please dont unplug that else though your XBOX would be connected to Modem or router but it wont get internet connection)
Aug 01, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
My Xbox 360 Says No Wireless Network, 192.168 takes me to ask.com!
I believe you are referring to the network key set on the Belkinrouter. Since you do not have the code, you will have to access yourrouter's web interface.
Let's begin with your router:
Using your working laptop, open Internet Explorer type 192.168.2.1 (default IP address of Belkin routers) press Enter. It will ask for a username and password - by default it'sadmin for both. If it does not accept admin, type in the username andpassword you set to your router when you installed it for the firsttime.
Once you open the setup page of the router, go to the Wireless tab ofthe router (located on the left side of the web interface. Look forSSID and WEP key or Network key (SSID is the name of your wireless network). Take note of the SSID and WEP keybecause you will need to set this on the XBOX console.
On the XBOX:
Open the dashboard settings - select Network Settings. Configure your XBOX to connect to your wireless network. When it ask for the network key - type in the code that you will see on the router's web interface.
Try the steps I mentioned, give us an update and I'll reply ASAP if you need further assistance.
Good luck and have a nice day!
Sep 30, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin g + mimo and xbox 360
are you typing the correct upper or lower case and not confusing zeros with the letter 'O'
Sep 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Router and xbox 360
You connect the adapter to your Xbox 360
May 20, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless router belkin n1
Right click on the network icon in your task bar and click view wireless networks, then when all the networks show delete them all and close the window, next, a pop up will say found wireless connections click the icon again and look for your connection in the list and click connect and enter the pass phrase
Nov 05, 2007 | Belkin (F5D8231-4) Wireless Router...
Belkin (F5D7231-4) Wireless Router Logo
82 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
