Question about Philips 190V6FB 19" LCD Monitor
Philips 190v monitor
My monitor comes on for a split second, shows picture, then goes off. Green light goes on and off at the same time. Can't seem to make it work. I've tried changing resolution, and have checked all conections. My guess is that it is inturnal. So, I took it apart and remove a fuse, tested it with an ohm meter, it checks good. Any suggestions?
I have had the same EXACT problem and it was driving me CRAZY!!! I took it to a local electronics handy man who changed the power source for me and it works just fine now, or I wouldnt be able to read you message now! It cost about 1/4 of the original price of the monitor to fix, but its worth it and the screen will last 3-4 years on top of the 2 I have had it already!
Posted on Jun 19, 2010
Computer screen goes to no picture after about 1
time for A new monitor or your video card is faulty
Oct 19, 2009 | Philips 190B6CB/27 19" LCD
Unwantred announcments in the center of the screen
This problem comes from the control switches on the front panel. I had the same problem and fixed it by opening the monitor (unscrew 3 screws on the back side, remove plastic shape of the stand, unscrew 5 screws of the stand and open the back; unscrew the 2 screws of the button switch panel). Now inject contact spray on every switch button. If the problem remains you may have to replace the button swithces. Thats all!
Oct 12, 2009 | Philips 190V6FB 19" LCD Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Screen flashes only for a split-second (as a second display for an iMac)
The inverter is faulty.If your Monitor is powered by a mains'kettle' type lead,then it MAY be repairable,provided you can find someone to do it.If you have an external power supply,then the chances are you have a separate inverter,and it is doubtful whetther you can find the fault or a replacement circuit board....which is why we have become a throw away nation !!
Viewsonic VA903b Flashing green light (slow)
Hi..there,
It's seems you got a busted backlight inverter problems... Need replaced with a new one. Happy Holidays!
Dec 03, 2008 | ViewSonic VA903B Monitor
My Sceptre X7 LCD computer monitor comes on at startup and goes black after about two seconds. I turn the monitor off and on again and the picture comes on foe about 2 seconds and then goes out again. The...
SORRY MONITORS R MONITORS THEY EITHER WORK OR THEY DON'T. WARRANTIES R THE BEST THINGS FOR MONITORS.HAVE U TRIED THE COMPUTER ON ANOTHER SYSTEM TO MAKE SURE YOUR VIDEO OUTPUT ON THE COMPUTER IS WORKING CORRECTLY
Aug 11, 2008 | Computers & Internet
Display works - but only for a plit second...
Lower your resolution on your computer. Usually when that happens the resolution is set higher than what the monitor can support. Lower the resolution and try again.
Jul 25, 2007 | Dell E173FP 17" LCD Monitor
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
LG Flatron L1951S-SN 19 in. Flat Panel picture problem
When the picture disappears again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
Mar 15, 2007 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Philips 190V6FB 19" LCD Monitor Logo
1,749 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
