Question about IBM Netvista Intel Pentium 4 2.4GHz / 512MB DDR / 40GB HDD / DVD-ROM / 10/100Mbps LAN / Windows XP P (RBP42400XPP) PC Desktop
Administrator password i have forgot my password, how can i fix this?
Suggest a Solution for this Problem
Sandeepatil_ss@yahoo.com
Posted on May 21, 2008
Recover administrative password,forgot password
hi there.
Method 1 - Reset password from another Administrator account:
  1. Log on to Windows by using an Administrator account that has a password that you remember. ...
  2. Click Start.
  3. Click Run.
  4. In the Open box, type "control userpasswords2?.
  5. Click Ok.
  6. Click the user account that you forgot the password for.
  7. Click Reset Password.
More items...
I FORGOT MY ADMINISTRATOR PASSWORD ! - HP Support Forum ...
https://h30434.www3.hp.com/...Recovery/...ADMINISTRATOR-PASSWORD/.../24703...
if this does not work go to this link and read up some more.
Recover administrative password Google Search
Nov 20, 2017 | Computers & Internet
Tip
Lost windows password? you can go into safe mode (F8 when booting up) to reset...
Last week when my friend bought a Windows XP installed netbook, he created a complex Windows login password to bolster the privacy of his netbook. Unfortunately, he couldn't remember the spelling of his own password the next day and was unable to use his netbook. I suggested Windows Password Key 8.0 to reset the password and start using his netbook again. Let’s find out more about Windows Password Key 8.0.
Windows Password Key 8.0 is a useful application, which can be used to reset the Windows login password on your netbook with the help of USB flash drive. Windows Password Key 8.0 is compatible with all versions of Windows.
However, your netbook must have minimum system requirements to enable Windows Password Key 8.0 to reset your Windows login password. First, your Windows must be installed in a FAT-16, FAT-32 or NTFS partition and you must also have bootable USB flash drive to reset the password.
You'll need to install Windows Password Key 8.0 on any other Windows PC, which is accesible to you. Once the installation is complete, Windows Password Key 8.0 will launch on the screen.
In the Windows Password Key 8.0 window, you'll need to select the existing Windows Password Key 8.0 image, which is ideally located as a default option under ‘Choose the existing windows password key 8.0’.
Select the option ‘USB Flash Drive’ and insert your USB flash drive in the USB port. After you insert the USB flash drive, select it from the drop down list and click the ‘Burn’ button.
When the ‘burning’ process starts, Windows Password Key 8.0 extracts the ISO image and copies the necessary Windows files to your USB flash drive.
Now you can insert your newly created USB flash drive into your netbook port, and then reboot your operating system. Be sure to change your netbook set up to make it boot from your USB flash drive.
When your operating system boots from your USB flash drive, the Windows Password Key 8.0 will initialize on your netbook screen. You need to select ‘Windows installation to be processed’ and then select the user, whose password you need to reset by typing the number associated with it, followed by the ‘ENTER’ key.
In the next screen, type ‘Y’ followed by ‘ENTER’ to reset a new password.
After you reset a new password, remove the Windows Password Key 8.0 bootable USB flash drive and restart your netbook to log in using your new password.
It is always a good practice to set up a simple password for our windows login. Although we have utility applications like Windows Password Key 8.0 for our rescue, it becomes a tedious task to reset password, especially when you are travelling with important documents on your netbook.
on Jan 13, 2010 | Computers & Internet
Forgot administrator password,how do you fix it?
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
There is a free boot CD called Hirens.
Oct 11, 2012 | Dell Computers & Internet
Forgot password no resset disk
Oct 04, 2012 | eMachines Computers & Internet
Forgot my computer logon password, cannot use computer
Don't panic there is a much easier solution.
Most likely you just changed the user account password which means the administrator password is still set at default (blank)
Push F8 several times before the WindowsXP animation pops up on load. Choose safe mode. In save mode choose user Administrator and you should be able to log in with a blank password. After that go to control panel/user accounts and remove the password on your user account. After that - reboot.
If you also set and forgot the Administrator password there are utilities that will clear that for you. What comes to mind first is the Active Password Changer. Look for it on the web.
http://www.dllerrors-fix.com/
Dec 09, 2011 | Sony VAIO VPCEB3RFX/V Laptop
I need help i have forgot the power on password for my hp compaq 6720 and need to know how to by pass it thanks
Here I collect some popular solutions to help reset HP laptop password if your laptop installed Windows system such as Windows 7/Vista/XP.
Solution 1 Reset HP laptop password by another user account with administrator privilege.
Solution 2 Reset HP laptop password with Offline Windows Password & Registry Editor.
Solution 3 Reset HP password with professional password recovery tool.
If you do not have another administrator account on HP laptop or you have little experience in Windows or LUNIX operations, you can use Windows Password Rescuer to help reset HP password without lose date. This software was provided by DAOSSOFT corperation, it supports HP laptop password recovery in Windows 7/Vista/XP and HP computer installed Windows 7/Vista/XP/2008/2003/2000.
Sep 13, 2011 | HP Compaq 6720s Notebook
I forgot my password and when i turn my computer on it has a black screen and a blue box in the middle ask for current password , when i try a password it tells me that password check fail with a white box...
Try administrator with no password to log on. Sometimes the default administrator account has not been set a password.
You can reset a lost or forgot Windows password with 4 methods below:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc.
3. Third-party software to create a bootable password reset CD/DVD or USB, like Windows Password Breaker.
4. Re-install. Will lose data.
Jan 13, 2011 | Acer Aspire One PC Notebook
Forgot my administrator password fopr sony snaplab
both keywqords dont work. where can i reset to the default password
Mar 07, 2010 | Sony SnapLab UP-CR10L Digital Photo...
How do I reset administrator password
click start
control panel
switch to classic view
click user accounts
then click computer administrator
change password
Feb 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
I forgot my password on my computer
I know a windows password recovery tool called windows password buster. This software could help you recover the password.
Nov 28, 2009 | HP Computers & Internet
IBM Netvista Intel Pentium 4 2.4GHz / 512MB DDR / 40GB HDD / DVD-ROM / 10/100Mbps LAN / Windows XP P (RBP42400XPP) PC Desktop Logo
56 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
