Question about Minolta magicolor 2400W Laser Printer
Rotate Toner Button Does not Work
My rotate tomer button hasn't worked in a long time. Recently my printer tells to that cartridges I have already replaced need to be replaced. Are the two related?
  • Anonymous Mar 26, 2009
    seems like the tracks are off their belt on magic color 200w
How do you change four toner cartridges-Minolta 2400w Printer?
Posted on Oct 11, 2008
When I put a new Brother tonner cartridge into my machine it keeps telling me toner error and reinstall drum unit I have tried everything and it still wont work HELP
Make sure it's not Upside down try pushing the red reset button ,or rotate the white gear tward the bottom. What's the model ?.
Feb 24, 2015 | Brother MFC-8860DN Printer
Xerox 6120 will not rotate cartridge
I have a xerox n2125 laser printer and the multi bypass feeder does not work, can you advise me in how to fix it>
Mar 17, 2010 | Xerox Phaser 6120N Printer
Keep Getting Error Message "(Colour) Toner Not Installed"
I think in the menu you have to select replace cartride.. then new or same with new toner...
each toner cartridge has connections and you must make sure all are tight... or you get alot of errors.
Sep 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Cartridge replacement issue
I posted the solution to this problem on another thread I started. You can read it for more details.
Here it is in a nutshell...
FIrst, turn off the pinter. SAFETY is most important.
There is a switch or button to the left of the hole where you slide in the toner cartridge. It is in a squarish hole, the button is circular or cylinder shaped. This switch or button releases the cartridges so you can manually rotate them. Push that button in with a small screw driver, then gently rotate your particular color cartrige out of view from the hole. This engages the cartrige so that the printer recognizes it is installed. Release the button, close the door, and turn on the printer.
It if works for you, send me an email at chc1@yahoo.com
I'm also the poster fot the solution to "fatal error 16H".
Sep 09, 2008 | Konica Minolta magicolor 2300DL Laser...
How to remove the toner cartridges
Close the cover to the machine and make sure you aren't getting any other error messages other than the toner. When the printer is at the ready state press the rotate toner button. You should hear the printer rotate the toner and then the light over the cyan cartridge will come on. Keep pressing the rotate toner button until you get to the color you want to replace. Open the top cover and front door where the KM logo is. You should see the cyan cartridge in place. Pull the cyan tab back toward you. The front part of the toner should release. Now pull the tab and the toner straight up and out of the printer. If you are having problems getting the toner out it is probably not in the correct position. There is a slot on either side of the printer that he back end of the toner cartridge needs to be in before the toner will come out.
Jul 10, 2008 | Minolta magicolor 2400W Laser Printer
How to rotate toners
To rotate the toners:
1 press the down arrow until reset menu appears press the right hand arrow once
2 Scroll through the menu until change toner appears.
3 Toner C appears first continue scrolling until you reach the desired toner eg K for black then.
4 Press the right hand button and the red light will appear on yhe main button.
5 Open front door and change toner.
Works for me after hours of searching. Hope it works for you.
Jul 03, 2008 | Epson Aculaser C1100 Printer
Rotate Toner Button and Replace Cartridge Messages
Hello
take out all toners and pc drum, use pressure air to clean chip reader under the toner rack (right side) also use some alcohol to clean chips on toners and reinstall.
May 20, 2008 | Minolta magicolor 2400W Laser Printer
How to change cartridge in magicolor 2500W?
If one of the cartridges needs to be changed, the printer will recognize this and it will automatically rotate that cartridge to the front of the printer.
Open the panel and follow the instructions that are shown on a sticker on the inside of the access panel. Removing the cartridges is not difficult. They do have a slight groove near the top that acts as a handle. You may have to rotate the cartridge up as you lift it in order to get it to come out. DO NOT FORCE IT. Once again, please consult the sticker on the inside of the access panel for details on cartridge replacement.
If you need to replace more than one cartridge, press the rotate button to rotate the cartridges to the one that needs replacing and repeat the process.
DO NOT FORGET TO TAKE THE SEALING STRIP OUT OF THE NEW TONER CARTRIDGE BEFORE PUTTING IT IN AS THIS TAB CAN AND MOST LIKELY WILL DAMAGE THE PRINTER. (I've seen it happen.)
After you have replaced the toner cartridges properly, the printer should rotate the drum a few times to prime the cartridges. This is normal. You should see a readout on the LCD screen of the toner levels. (You may have to press a few buttons to see the status on them.)
If you need toner cartridges, head to your nearest office supply store such as Staples or Office Depot for replacements. (Staples will price match other stores if you give them proof of the other store's price.) When I last worked with this machine, the cartridges were still kind of expensive...but worth it for the quality that this machine gives you.
Good luck. :)
Cyryl
Nov 09, 2007 | Konica Minolta magicolor 2500W Laser...
Installing new black print cartridge
Manually Removing Toner for magicolor 2400W
1.  Hold down the Cancel button for 10 seconds or longer.
2.  With the Cancel button still held down, also simultaneously hold down the Rotate Toner button for 10 seconds or longer.
3.  When all LED indicators are blinking rapidly, release both the Cancel and Rotate Toner buttons.
4.  Then hold down the Rotate Toner button again for another 10 seconds or longer.
5.  The Cyan toner cartridge moves into the proper position, so it can be removed.
6.  Remove and/or replace the Toner Cartridge if necessary.
7.  Open and close the covers. Each time you do this, another toner cartridge moves into the proper position, so it can be removed and/or replaced (in this order: cyan, black, yellow, magenta).
The link is located here
Oct 21, 2007 | Minolta magicolor 2400W Laser Printer
Minolta magicolor 2400W Laser Printer Logo
334 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
