Question about Saeco Caffe Charisma Espresso Machine
Saeco Vienna: water does not go through to the main unit
My Saeco Vienna is acting up after about 4 years of great work: when I turn it on, the pump goes, but no liquid coffee comes out. We figured the water from water tank does not get to the main unit, because the machine's 'garbage' bin contains dry ground coffee, not the round wet tablets. Any ideas? Thank you. After descaling & adjusting the grinder, everything worked fine for a day. Now when I went to make a cup of coffee, water went into the dump box, instead of my cup. I tried cleaning the brew group again but still no change. I hope no one has this problem, it's so frustrating.
Lisa
  • bmiklos Sep 11, 2008
    I get some coffee, but less than before - and the dump box is also filling with water (the missing water!). Something is blocked somewhere but I can't figure it out. Help please.
  • Anonymous Feb 28, 2009
    Cafe charisma does not let water go through the ground beans.  The by-pass (for decaf) works as does the steamer and frother.
  • 2,039 Answers
On the brew unit the plastic screw that hold the filter mush be loose or broken check that out pierre
Posted on May 22, 2008
No water/steam coming out of wand
hi there,
do you hear the pump running when you ask for water or steam? You should hear the pump continuously when you ask for hot water, and intermittently when the steam is dispensed.
No hot water or no steam could come from many causes:
valve not working or not actuated (control board), and also the switch that closes when the water knob is turned may be defective.
Do you hear that switch clicking when you open the water knob?
Difficult to help further with so little behaviour information.
Good luck,
M.
Oct 28, 2017 | Saeco Vienna Plus Espresso Machine
Saeco vienna super automatica coffe maker produces very little coffee and it comes out very slow.
sounds like your pump. When you turn steam knob on, you should hear the pump go bump,bump,bump. When hot water is turned on, you should hear pump run steady.
Jan 07, 2013 | Saeco Vienna SuperAutomatica Coffee...
I own a saeco Vienna 'limited edition'. When making coffee, the cycle stops when the water pump starts. Coffee light blinks and the red light turns on. It started when i tried to use the steam...
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
Sep 24, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Sup018 model. Changed flowmeter and sensor because of water flow problem. Now the unit makes one cup and red light comes on. Turn off machine to reset. Pump work fine, no clogs anywhere. Any...
hi
i had the same problem , you placed the chip with 3 legs on the wrong side turn it over and it will be ok .the writing on the chip of flow meter should face down.
Apr 12, 2011 | Saeco Vienna SuperAutomatica Coffee...
On my saeco vienna machine i hear the pump working but no water is coming through
Any water leaks following the pumping sound ?
If there is no leaks, I would try to get some hot water from the wand.
If there is still no water coming out, I would:
1-Decalcify thoroughly
2-Open the machine and take the inside out and verify the status of the water pipes going from the water tank to the boiler than to the wand and the brew unit ... to make sure there is no restriction.
3-Replace water pump
Jan 25, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Superautomatica will not make a full cup of coffee
I'm wondering if you had any luck solving this? After 3 years of great coffee, my machine is only making a 1/4 cup or so. All parts are clean. I'm guessing something on the circuit board that the dial is attached to....thanks!
Feb 27, 2010 | Saeco Vienna SuperAutomatica Coffee...
Low water pressure
i had the same problem the brew unit was block from many shot remove the little tube on top of brew unit be carefull after removing the 2 screw there a spring under the tube and glass ball clean it good
Apr 09, 2009 | Saeco Vienna Deluxe
Resover leaking
The easy fix for leaking under the machine is check to see if the drain is clogged. Open the front and remove the brew unit. You will see a small hole that will drain the excess into the Plastic tray. Usualy I find Coffee grounds clogging the drain hole. Use Pipe Cleaner , Q-Tip to clear the drain hole. you can also wipe out from the other side with paper towel or Q-tips. once the clog is clear. Flush our with water.
Feb 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
Trouble with Saeco Vienna Deluxe
Could be the pump gone bad or the flow meter.
Neither is easy to replace. Needs to be brought in for fixing.
Apr 16, 2008 | Saeco Vienna De Luxe Espresso Machine
I had the same problem and got on the Saeco US website and talked to an online support person. She downloaded me a couple of pages of "fixes", I tried them and they worked! You have to take the two screws out of the brew group, remove the spring and a little clear plastic ball. Then clean out the hole thoroughly. I stuck a toothpick up into it from underneath to clean out the coffee that was stuck in the hole. I then put it back together and now it works perfectly.
Dec 13, 2007 | Saeco Vienna Espresso Machine
Saeco Caffe Charisma Espresso Machine Logo
274 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
