Question about Solis Palazzo Espresso Machine
Solis pallazzo rapid steam
when i turn on the unit the three central lights begin flashing and no button responds. If I turn it on while pressing the 2 right buttons then the 2 left buttons (water and coffe) remain red - not flashing. I cannot get it to work. Any tips to reset it or troubleshoot it? Does the company have a support number?
Any help is appreciated
Thanks
Alex
  • joeer6 Sep 15, 2008
    I have a Solis Master Top 517 and two red light on the left and two on the right comes on but when I push the button I am not getting any respons.
    Can you help please.
  • RWFarrington Oct 15, 2008
    I have the same problem with my solis palazzo espresso machine regarding lights and how to reset. Any suggestions.
    Thank you,
    Randy
    RWFarrington@msn.com.
My machine clogged when i was cleaning it what can I do?
Posted on Jul 16, 2008
  • 515 Answers
Hi Alex,
Try to prime the machine.
Giro plus - red light flashes rapidly, tried priming with no success. Anyone have any answers?
Have you tried draining off some back-pressure. That often is what the rapid flash means. Try pushing the hot water button then opening the steam valve. A few seconds after the pump comes on to push water out, the red light should go off. If it takes more than a few seconds, that's probably not the problem. hope this helps.
Sep 27, 2014 | Saeco Odea Giro Plus Coffee Maker
Solis pallazo rapid steam. I can't remember how to clean the system
Descaling the Palazzo: The Palazzo is programmed to descale the boilers on its own, when set in the correct mode. You program the machine to descale it's self, do the following. With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in 32 to 48 oz in your water tank. Stir until they are completely dissolved in the water. Next, have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz's. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don't turn off anything until the machine stops on its own. This will clear the descale light. Refill the water tank again with fresh water and your ready to go.
Sep 10, 2010 | Solis Palazzo Espresso Machine
My Solis SL-90 has an issue where when you press the on button the pump starts. Also does anyone know if the 110V circuit board is the same as the 220V one ?
Hi
110v and 220v are not the same.
If the pump starts when you turn ton the machine the steam knob is out of adjustment. If you turn the knob to far you can do this. Remember that the steam knob does not close the steam off. It only pushes a needle with a seat on it to open. When you turn the valve off it allows the needle with a seat to stop the steam. Turning to far only moves the valve farther from the needle and pretty soon it will not open the needle.
Dec 18, 2009 | Solis Crema SL-90 Espresso Machine
Need to buy water tank of solis pallazzo coffee maker
The only importer of solis I know of is Barratza.com, they will have the parts needed.
May 29, 2009 | Solis Master 5000 Espresso Machine
Water tank light is flashing with main heating light
HI
I don't think your machine is finished descaling. Follow these steps.
With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in 32 to 48 oz in your water tank. Stir until they are completely dissolved in the water. Next have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz’s. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don’t turn off anything until the machine stops on its own. This will clear the descale light. Refill the water tank again with fresh water and your ready to go.
Apr 13, 2009 | Solis Palazzo Espresso Machine
Water LED flash
Hi
Try pushing the water button on the right ( it should light though dim ) and then open the steam knob.
Apr 01, 2009 | Solis Palazzo Espresso Machine
Solis Palazzo Descaling (?) Problem? Please Help!
Hi
He has the first part correct, but when you rinse the machine with fresh water the machine needs to quit on its own and you will know this when the descale light is off, but you will have a flashing green light and a steady red light over the water drop. Refill the water tank, the close the steam knob and then open it again. This will clear the red light and then the machine will start heating. IMPORTANT on any automatic machine is when the water tank is off the machine don't do anything with the beans. A chip of bean in the water receptacle can be a big problem for the machine.
Jan 28, 2009 | Solis Palazzo Espresso Machine
Solis rapid Steam stuck in descaling cycle
try to run a new descaling to see if it works normal again.
/Mirran
Sep 22, 2008 | Solis Palazzo Espresso Machine
Solis Pallazzo espresso machine - need maintence manual
Hi, check under: http://www.solis.ch/franzoesisch/kundendienst/kundendienst_f.htm
and choose your machine, under E (english) column, you'll get the pdf.
Aug 30, 2008 | Solis Palazzo Espresso Machine
Solis Palazzo Espresso Machine Logo
301 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Mike Cairns
Mike Cairns
Richard Roth
Richard Roth
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
