Question about Miele Vacuums
Miele White Star SEB 204, powerhead stopped spinning. brushes are clear of debris, belt (#3854940) is not broken. Could belt be stretched so that brush head does not spin?
  • Anonymous Mar 17, 2014
    I' replaced the belt 1 year ago.Not sure it was correctly inserted.
    Debris are stuck between the brush and it doesn't pick up also cat's fur
    President:
  • 1,673 Answers
Yes, most likely the belt has stretch. Flat belts do this after a short time and need to be replaced when problems start with the brush roll not wanting to turn. Also check the brush roll, make sure that the ends turn freely, if not, then replace it also.
Posted on May 20, 2008
Why won't brushes go round
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try. First, check your vacuums brushroll. It may simply be jammed and if so just remove any debris that is preventing it from spinning. If that does not work the issue may be related to your brushroll bearings. Try removing the brushroll assembly and clean all the debris from the brushroll bearing.
If this does not work, the issue may be related to your vacuums belt. Over time the belt can become stretched out, broken, or simply fall off. If the issue is related to your belt, you will need to purchase a replacement belt.
You can purchase direct your replacement Miele vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/miele.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jul 17, 2014 | Miele Vacuums
Miele seb 213 quit spinning on rug
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first let's focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Miele replacement parts for your Miele Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=miele
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Apr 14, 2013 | Miele SEB 213-2 Vacuum
Miele Vacuum(Saturn300). Vacuum powerhead(SEB234/236) does not work, no light comes on and no power. is it the hose(SES119) or the powerhead? tried plugging and unplugging.
You need to check your voltage coming out of your hose and wand, be sure that the handle switch is in the on position. Voltage should be +/-120V. If you have voltage there then you have a power head issue. The replacement would be the SEB 228, you could also use the SEB 236. The SEB 236 is a deluxe version of the SEB 228.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Feb 24, 2013 | Miele Vacuums
Miele SEB-213 powerbrush stopped working
Pull the head cover off to check the belt, if the belt is ok then it might be the power connection between the handle and the power head shaft. If the red light is on the power head, then its not the connection
because its getting power. Now some heads have a reset button on them,you could check this also.
With the cover off the power head, remove the belt, now turn it on, and be careful, but try to make the motor shaft spin,with one finger, because if it does start to spin you do not want to hurt your finger.
If the motor starts to spin,put the belt back on, if it does not spin again, the motor is too weak.
If it does not spin at all, the motor is bad.Hope this helps you,and you get it working.
Mar 24, 2009 | Miele SEB 213-2 Vacuum
Meile SEB 213 powerbrush cuts out
Your problem is either in the wand, assuming you have the telescopic dark grey electric wand. The only other thing it could be is the hose, once again, assuming you have the electric hose with either the rocker switch that shuts down the power brush, or the deluxe hose, with the electronic suction control, as well as the brush shut off. Miele wands and hoses are notorious for causing power brushes to cut off. If your Miele is under two years old, I would suggest taking it to a autherized Miele service center, and see what, if any, warranty you have left, and have it checked out. Let me know how you make out.
Jan 14, 2009 | Miele SEB 213-2 Vacuum
Powerhead on rainbow not working
If the motor is NOT running - press the red button on the nozzle (assuming you have the model with the button on the nozzle)
If it stops working as soon as you release the button - you need a new circuit breaker. If Motor in the nozzle works but brush does not spin - you have to replace the belt.
Good Luck
Nov 20, 2008 | Rainbow 75th Anniversary Canister Vacuum
New Miele Red Star - Powerbrush not working
Wish you had listed the model number of the vac and of the powerhead. The plug going into the cannister, is it pushed all of the way in, also same for the plug going into the hose end? You can hook up the powerhead plug to a/c and see if it runs, if it does, then it is ok. Unhook the hose and plug and hook up a/c to that plug end and see if the powerhead will run, if not maybe the switch on the hose handle has a problem. Otherwise you have a problem in the cannister. If this is brand new, then it has a warranty, take in for repair.
Feb 21, 2008 | Miele Red Star Bagged Canister Vacuum
Kirby g4
first things first...take the powerhead off of the front of the kirby. If you look at where the powerhead connects to the front of the kirby and you'll see a large hook...turn the hook using the crank on the front of the powerhead so that the belt is pulled up and away from the brushes. (OFF position) The hook stretches the belt so that it can fit over the fan driveshaft (its the finger looking thing that sticks out of the front of the kirby when the powerhead is removed.)
Next, place the two "feet" of the powerhead onto the "perch" located on the front of the kirby (under the driveshaft opening)....lock it on by turning the silver lever on the top of the kirby (the one under the hood/light)
Now spin the knob on the front of the kirby from off to on. This releases the belt from that hook in the powerhead so it can rest on the driveshaft. Off means the belt is off of the drive shaft and the brushes won't spin. On means the belt is on the driveshaft and the brushes will be spinning. But remember, the belt has to be stretched open on that hook inside the power head BEFORE the powerhead is placed on the front of the kirby. Otherwise the belt won't be connected to the spinning driveshaft, and the brushes won't spin
Dec 08, 2007 | Vacuums
How to put the belt on ?
Dec 06, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Vacuums Logo
710 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
