The Xerox WorkCenter XD103f
I installed a stripped fussier gear of the copier. When I turned the copier on, I ran into another problem. The copier started flashing H and 4 alternatively. I am experiencing almost a complete short-down as the copier does not respond to any control. The start button does not show any light. How can I fix this problem. I appreciate your suggestions.
Nkem.
  • NKEM May 21, 2008
    Guru, you are awesome! You solved my problem. Thanks a lot and keep-up the good work.
    Nkem
  • kenn2 Oct 15, 2008
    Please teach me how to set originals in DP for a kyocera mita KM-1560kx copier
    President:
  • 2,072 Answers
First make sure both the hear rod and thermistor are plugged in. There are 2 plugs on that fuser then perform this procedure.
Then be sure that the heat rod did not break. After that..
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on May 20, 2008
  • Rick Kasper May 21, 2008
    Glad it worked.
  • normanys Dec 07, 2010
    I got the same problem with above mention (E7) on my XD103F, but still can't solve with this resetting procedure. The scanner lamp (green bar below the glass) was not moving completely to the end of the media and only move for approximately 1 cm and back to the start position. This problem was occur after I put the unit on the floor when hard raining.
    What should I do to solve this problem?
    Thanks for the help.
Which cartridge is used in workcenter pe16e
Hello
Xerox 113R00667 Genuine Xerox Toner Cartridge for Workcenter PE16E
You can get more information from here
http://www.tonercartridgedepot.com/xerox-workcentre-pe16-5759-d.html
Good Luck, and do rate the solution if got help
Dec 26, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
Ow to change resolution in xerox workcenter pe16 scanner
resolution for impression or copie if impression enter from propriété printer if copie you choose it from screen
May 28, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
ANNOT GET INTO TCHE MEMORY CLEAR SCREEN OF XEROX WORKCENTER M15
that is perfectly normal. That maintains the lamp temperature.
Not a big deal.
Feb 25, 2009 | Xerox WorkCentre M15i Laser Printer
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Workcenter xd103f copy comes out blank
Which cartridge did you change? If its the toner cartridge, make sure none of the packaging materal is left on it, same with the drum cartridge. First and simply remove and reseat the cartridges.
What I suspect with the blank copies is a broken transfer corotron wire.
Open the right side door. On the bottom you will see some whit plastic rollers. Above that you will see an opening about 1/2 inch wide. There is a very thin wire in that channel. That wire has probably broken causing your blank copies, I highly suspect that is broken.. That wire when it is dirty also causes really poor copy quality.
Also clean all the mirrors and glass well. That will cause poor copy quaility issues.
Mar 12, 2008 | Xerox WorkCentre XD103F All-In-One Laser...
232 people viewed this question
jasbo
jasbo
