SOURCE: Samsung Electric Dryer
I have had the same problem with mine, they (being the repairman) came out and have replaced the sensor and the board and it still does this, they said that there is nothing else that they can do. Don't know what I am going to do from here
SOURCE: samsung dryer is not drying and its new
It ended up being a easy fix. Our old dryer was working fine and had been ran an hour before I hooked up the new Samsung dryer. Therefore I assumed when the new dryer did not work there had to be something wrong with it. There ended up being nothing wrong with it and it was my dryer vent. It was barley plugged which caused it to not heat up properly. I was told that the new dryers have a lot more sensors on them and its very sensitive about needing a clean vent to vent out the heat. My vent was not very dirty, but it had just enough build up of lent in it, it caused the dryer to not vent properly and it would keep shutting the flame off. Blew it out with my leaf blower and now it heats up and dry quick. I hope this helps
SOURCE: DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
SOURCE: need to take case off dryer there is something stuck inside because kids dried with lint screen out
SOMETHING IN THE BLOWER WHEEL CAUSING A OBSTRUCTION AND MOTOR WILL NOT START. START AT THE TOP THEN FRONT WILL COME OFF
SOURCE: 2 yr old samsung dryer does not dry clothes totally
Remove the vent completely and clean it out 100 percent. Elbows (corner bends) will hold more than you think causing the dryer to keep the heat off. The sensors for the newer style dryers detect plugged up vents and shut down the heating modes. If cleaned and still no heat the spark ignitor has gone bad
