power steering pump is mounted on front of engine where the tming gears are. Shaft leaks into crankase. Hydraulic fluid circulates through transmission, main system and power steering. Common problem with the 1020.
Try changeing the hydrolic and transmission filters,also recheck the fluid level.Check the fluid level with all cylinders retracted and if it is overfull then drain it to the top of the full line.
ck on traction motors for lever or nut to release fluid. Can you move mower with engine off? If so, this is your what is wrong traction motors are disengage
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
