Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool gold self cleaning oven
My oven light would not work, so I replaced it with a new one and it still won't work.... why?
  • Brandyleev May 21, 2008
    LOL.... how embarassing... it wasn't screwed in all the way lol.... Thanx
  • 868 Answers
Is it screwed all the way in??Using a meter test the bulb socket for power.If its showing no power check the light switch
Posted on May 21, 2008
Whirlpool self-cleaning feature not available
Because the features mention utilize 220 VAC power, I do not advise you attempt any corrections. Very dangerous; unless you are a trained technician. If the unit is in Warranty, get the Whirlpool folks out to you home ASAP.
Dec 19, 2013 | Whirlpool Gold GGE388LX Double Oven...
Whirlpool #rbs245prb04 oven won't work after self clean
Check the probe sensor.Measure sensor resistance. It should be (1080 Ohms at 70 degrees F . Add 2 Ohms per degree F). If resistance is not valid, replace sensor. Here is the part to order.
Keep me posted.
Nov 27, 2012 | Kitchen Ranges
I have a Whirlpool Gold self-cleaning oven w/convection. Following a self-cleaning cycle the oven will not heat up. Is there a certain amount of down time that has to go by before it will function again...
The self-clean cycle has blown a fuse in the rear of the oven. That thermal fuse must be replaced. Go to and enter your model number. Find the thermal fuse on the diagram and then you can orfer the fuse from them.
Aug 27, 2011 | Whirlpool Ovens
Whirlpool Gold Self-Cleaning Oven Error Message: E1 F5. What does it mean and can I fix it?
E1-F5 means the self clean latch will not lock.
Try pressing down any key and hold for 1 minute, see if this clears it. If not you will most likely need the latch switch replacing.
Dec 20, 2010 | Ovens
I self cleaned my oven last night and I noticed the electrical(clock and oven control panel) does not work. The burners work and the oven door does not open
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 24, 2010 | Whirlpool Gold GW399LXU Gas Range
Self cleaning oven won't start self clean mode
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven broiler and auto clean not working.
if the oven broiler isnt working self clean wont either check the broiler element to see if its burned out pretty easy to replace most of the times you can replace it from inside the oven be sure to turn the power off then remove the two retainers from inside and pull element out
Jan 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Wont lock in self clean
Whirlpool Gold range: start the self cleaning but after message: cln door comes message, E1-F5- . door does not lock and cleaning can not start.
Oct 10, 2008 | Thermador C302U Electric Double Oven
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
Thank you
Agent Matt
Go Ahead. Use Us.
Apr 07, 2008 | Amana ARGS7650SS Gas Kitchen Range
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
121 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
