Question about HP PSC 1315 All-In-One InkJet Printer
Paper jam Hi, I have a HP PSC 1315 printer. It was working fine until yesterday it started giving the "paper error" message. I checked everything and there's no paper stuck. I also aligned the print cartridges in case they were stuck. I even turned it on and off, but nothing works! if you have any suggestions, then please help. Thanks
Maskooor
Posted on May 27, 2008
Continue to receive E error message
Check control panel lights, if cartridge led's are blinking replace particular cartridge, if paper led's are blinking check any paper jam inside, if no paper found clean paper sensor.
Nov 24, 2011 | HP PSC 1315 All-In-One InkJet Printer
I have a psc 1315 all in one printer. When I turn it on it shows it has paper and no errors. When I go to print it won't feed in the paper and just goes into error mode and says check paper. I have the...
try resetting the printer:
  1. Turn on the PSC 1315 by pressing the "On/Resume" button until it lights up. Ensure the printer's USB cable is securely plugged into the back of the machine and the attached computer.
  2. Remove the power cord from the back of the printer. Do not unplug the other end of the power cord from the power outlet.
  3. Press the power cord back onto the metal plugs located on the back of the printer. Make sure you insert the power cord completely into the plug area to ensure a proper connection.
  4. Press the "On/Resume" button on the printer's control panel until it lights up. Allow the printer to complete its warmup process.
  5. Attempt to print with the device if no error messages are displayed.
Mar 14, 2011 | HP PSC 1315 All-In-One InkJet Printer
My HP psc1315 will not turn on. Some of the
To be able to understand the problem, you should give extra info about the lights.
Please find the information below about the status lights that provide information about error conditions of your printer. But first you need to install the driver for your operating system. The drivers are necessary to print documents and scan images. These drivers must be installed to use the print and scan features.
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HP PSC.
2 Turn your HP PSC off and on by disconnecting the power cord and reconnecting.
Problem 1: “ON” light is on, “check paper” light is blinking and “check print cartridge light” is off .
Explanation 1: The paper tray is empty, the HP psc has a paper jam, or the paper size setting and paper in paper tray are not the same.
Solution 1:
• Load paper, or remove thepaper jam.
• Change paper in paper tray to correct size.
• Change paper size on the computer software.
Then press On/ Resume to continue.
NOT : PLS SEE THE NEXT MESSAGE. CONTINUED AS THE COMMENTS BELOW:
Mar 31, 2010 | HP PSC 1315 All-In-One InkJet Printer
Same or similar problem
Try to download the updated driver for this printer, I have the same problem and solved with the newest driver.
Jul 10, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp psc printer paper feed is jammed with an piece of paper.
The small gear located in the paper feed assambly is break or fail, need replacement parts to repair it.
May 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
Will not feed the paper.
it probably needs a roller assembly replaced
Jan 16, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
my printer no function cant print
Jun 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
252 people viewed this question
Seeker5211
Seeker5211
