Question about Mintek MDP-1760 Portable DVD Player
Mintek how do i get my portable dvd player to play movies, it just says loading and nothing plays, i can play music cd but not movies
  • 2,307 Answers
The part that reads the DVDs is defective. I would suggest to try cleaning it using a lens cleaner, hopefully that works.
If the cleaning does not work, it might just be cheaper to buy a new one instead of repairing this one.
Posted on May 20, 2008
Problem with Mintek MDP-1810 Portable DVD Player that will play movie DVDs but not computer burned video DVD
The problem I think is with the burner on your pc. Try re burning on another program like Nero and pay attention to the options. It will ask you if you wish to play disc in all types of players.
Dec 25, 2013 | Mintek MDP-1810 Portable DVD Player
Tip
Mintek factory solution for the forever loading disc problem.
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
on May 29, 2009 | Mintek MDP-1770 Portable DVD Player
No disc error
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Apr 22, 2009 | Mintek MDP-1810 Portable DVD Player
Portable dvd player
the laser may be broken,and can not read...
Apr 15, 2009 | Mintek MDP-1720 Portable DVD Player
Unable to play dvd's on my mintek portable dvd player
I would get an optical laser lense cleaner ( it is basically a cd that has fine soft brushes on the underside to clean the laser lense )
something like :
laser lense cleaner link
Apr 13, 2009 | Mintek MDP-1720 Portable DVD Player
Loading but nothing happens
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.I hope this information helps your problem.
Apr 07, 2009 | Mintek MDP-1810 Portable DVD Player
Says no disk
Jan 31, 2009 | Mintek MDP-1815 Portable DVD Player
My mintek dvd player says no disk
Dec 07, 2008 | Mintek MDP-1815 Portable DVD Player
Mintek mdp-1720
http://www1.epinions.com/content_209566011012
Try this link from someone with the same problem, and a possible solution. It is simple & got my player working albeit temperamentally.
Jun 07, 2008 | Mintek MDP-1770 Portable DVD Player
Will not play any DVD
Turn off and disconnect power from unit. Check laser shuttle worm gear, look for dirt or hair (as I found). Remove with tweezers carefully. Check lubrication of worm gear shaft. If gone or worn, use white lithium grease to lube (very little). Play music CD 2 - 3 x. Than DVD. Worked for me.
Jun 01, 2008 | Mintek DVD-1710 Portable DVD Player
Mintek MDP-1760 Portable DVD Player Logo
155 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
