Question about Bissell 6590 CleanView Bagless Upright Vacuum
Bissell 6590 handle height adjustment
Mine broke and I need to find a replacement but have not been able to find any sites that feature it.
  • Michele S. Shera May 21, 2008
    THANK YOU THANK YOU !!!!!
    President:
  • 1,673 Answers
The handle adjustment knob part # is 2031095, the height adjustment wheel asm. part # is 2031330. You might try bissell.com and see if you can order direct from them. If not, most repair shops should be able to order for you.
Posted on May 20, 2008
How do i detach the handle the adjustable handle it adjusts to a different height but i cannot remove it to pack it away
Hi, it's Jeremy from Crucial Vacuum.
In the link below you will find a link to your Bissell PowerGlide's owners manual. At the top of page 5 you will find instructions on how to detach your vacuum's handle from the base.
http://www.bissell.com/assets/0/132/134/228/c0654b9d-ef9b-4d91-8723-203b4ee6e70a.pdf
You can purchase direct your replacement Bissell PowerGlide parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=bissell+powerglide
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jul 29, 2014 | Bissell PowerGlide Deluxe Pet...
Bissell 3576 height adjustor broken
Hi Chris! Lock the vacuum in the upright position, set the height adjustment to the desired setting, then recline the handle for the change to be made.
If you continue having difficulty, you may want to have one of our Authorized Service Centers inspect your vacuum.
Here's a quick link to help you locate one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
May 19, 2013 | Bissell 3576 CleanView II Bagless Upright...
Still dont know hot to get height adjuster knob to work. tried handle all the way back n lay on side solution that was offered. the plate has a permanent place to sit. hows it possible to bring knob
Hey, not having a working height adjustment can be a bear. Lock the vacuum in the upright position, change the knob to desired setting, and recline the handle for adjustment to occur.
If you are still having difficulty, you may want to have your vacuum inspected by a Qualified Technician at one of our Authorized Service Centers. Here's a quick link to assist you in locating one.
Jan 03, 2013 | Bissell 6594 PowerForce Bagless Upright...
Bissell powertrak is stuck in the high position, knob moves/changes but the height stays on high
Hello. The height of the wheels Will stay in the highest position until you release the handle release lever. At that time the adjustment will happen. I hope this helps. let me know.
Aug 06, 2009 | Vacuums
Height adjustment not adjusting
The height adjustment wont engage unless the handle is in the down position. Not knowing this led me to overturn the hight adjustment knob.
Step on the handle release, pull the handle back and lay the vac on its side. Then you can get the knob and the plate back together again.
BTW, the reason I had this problem is because the front brush slows dramatically when using on carpet, I thought it was set too low, and turned the knob (in a manly fashion, putting it past its limit). Still working on that one. After inspecting the belt, looks like one worn and cracked spot gumming up the works.
Jun 21, 2009 | Bissell 3920 Bagless Upright Vacuum
Bissell 6590 wheel unit pins snapped, where can I get a replacement part
This is a very easy repair. I got a hose clamp. 1/2" wide, solid edge. Take your time and bend it the inside shape of the holder. drill 2 matching holes, It's a perfect fit.
Nov 02, 2008 | Bissell 6590 CleanView Bagless Upright...
Bissell 6590
It is called the detent lever part # 2030052. If you can't order it from bissell.com or over the phone, most repair shops should be able to order it for you.
May 21, 2008 | Bissell 6590 CleanView Bagless Upright...
HANDLE height adjustment just broke and I can not find any place that sells it. Any suggestions would be of great help. Thanks, Mafiabella
It i called a detent lever, part # 2030052. Usually a repair shop can order this for you. Or you might try bissell.com and see if you buy it online from them.
May 20, 2008 | Bissell 6590 CleanView Bagless Upright...
Too loud noise of Bissell 6590-W vacuum cleaner
When they get real loud either the motor bearings or the motor fan are bad and you will have to replace the motor, part #2031100, would sell for about $45.
Oct 04, 2007 | Bissell 6590 CleanView Bagless Upright...
Bissell 6590 CleanView Bagless Upright Vacuum Logo
582 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
