Question about HP PhotoSmart 7150 InkJet Printer
Windows does not recognize usb device
I have a dell inspiron laptop. i also have a hp photosm 7150 inkjet. my grandson knocked over prnter now windows does not recognize usb device. tried new usb cable. nothing. back of printer where usb cable and power cord are located seems to be loose and or bent. can i fix or must i bring to repair center?
    Sergeant:
    Champion:
  • 274 Answers
Probably broke a solder point. Need to take in for repair, or find a friend who is an electrician.
Note: Needs to use low heat solder.
Posted on Nov 24, 2008
I have problem with my usb not recognized.
go to the website and locate where you can download drivers/software, once you have done that look for the specific area and download the driver, or you can go to device manager and make sure the driver is working properly
Jul 16, 2010 | Dell Inspiron 8200 Notebook
I have a diamond mp3 hooked up to me laptop but windows media does not detect it. What do I need?
Unrecognized devices often mean hat the drivers are not installed or available in Window. Try installing them if you have a CD.
There are more possible problems with unrecognized USB devices, so I suggest you have a look here if the drivers don't solve the issue.
http://www.pcauthorities.com/drivers/usb-device-not-recognized
May 25, 2010 | Dell Inspiron 1501 Laptop
USB mouse problems with Windows 7 Laptops
You MUST disable digital driver signing to install ANY driver.software on any 64 bit system. you MUST press F8 at boot up to install the driver, & then EVERY time you boot up you MUST press F8 to disable driver signing to USE it too, every time....
Mar 06, 2010 | Dell Inspiron 1545 Notebook
I have a Dell Inspiron 9200 running Windows XP pro. The other day I was running an external hard drive through a USB port...and since then...all my USB ports will not recognize ANY device. They run power...
A remedy would be buying a card that goes into a slot on this pc that has usb ports- giving that a shot will help you other then that the motherboard would need to be replaced at this point the cheap way out would be to just by a card- Thanks
Aug 07, 2009 | Dell Inspiron 9200 Notebook
HP Deskjet Printer; D2460 USB connectivity problem.
Go to Control Panel > System > Hardware Tab > Device Manage > Universal Serial Bus Controllers > Delete or uninstall any usb root hubs. You may notice your mouse may stop working after this. Try a reboot and then windows should redetect usb devices. You may have to delete some other usb root hubs again if this does not work the first time.
Jun 29, 2009 | Dell Inspiron 9100 XPS Latitude D400...
Usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
USB device not recognized
This solution worked for me when I got the USB device not recognized message:
http://www.infobarrel.com/USB_Port_Repair
It can be quite frustrating. I've heard that older computers are more likely to have the USB device not recognized message.
May 31, 2009 | Dell Inspiron 6400 Notebook
Cannot connect a hp psc 2410 printer to dell inspiron 1000 laptop
Try a powered USB hub, this will boost the power in the USB curcuit.
Also ensure that in Device Manager, USB Root HUB, Power Management tab, that the option to let windows turn off the device is unchecked.
May 27, 2009 | Dell Inspiron 1000 Notebook
Usb 8.0 gb flash drive not recognized by Dell 1521 inspiron
You will need the HCSD driver/patch.
http://support.microsoft.com/kb/923293
Hope this helps
Regards
Richard.
Apr 21, 2009 | Dell Inspiron 1521 Laptop
Can't re-load hp photosmart 7150 on windows xp. Gets to the point where the installshield should come up, lingers awhile, and then says check printer power and usb connection. The computer has already...
1.It could be the USB cable. Try a new cable.
2. Could be USB port, use another if available
3. You should be able to install the software without the printer connected.
4. Uninstall all hp printer software, and restart computer.
5. Delete any instances of the printer from the printer/fax located in control panel
Apr 15, 2009 | HP PhotoSmart 7150 InkJet Printer
HP PhotoSmart 7150 InkJet Printer Logo
150 people viewed this question
Ben Johnson
