Question about Sony Hi8 Hi-8 Tape
Tape is stuck
I have a stuck tape in a Sony videi Hi8 Handycam. I was changing tapes and the new tape made it most of the down and got stuck. I think a small cord got in the tape compartment when the camera starting to run. Now it beeps and shows an up arrow on viewfinder. Can't get the tape to go up or down.
  • lhoover May 20, 2008
    It's better - the tape went in and runs, rewinds, etc. However, I can't get it to eject. When I push the eject button, the compartment holding the tape extends but won't release the tape.
    Thanks all - it works now! It helped to squeeze or put pressure on the on the carriage.
    Thanks much.
  • 3,037 Answers
First take out the battery. Then start unscrewing the outside panels to take it apart. Basically any screw you find, take off. The easiest way not to loose them is by sticking them into the side of a box. After you get the camera panels off, you should be able to carefully get inside and dislodge anything that may be in the way. Once you are able to dislodge the cord or whatever is causing this problem. Try inserting the battery and ejecting the tape. Let me know if you are having any trouble with this or have any other questions and I would be glad to help.
Good luck
Posted on May 20, 2008
  • Benjamin Patri
    Benjamin Patri May 20, 2008
    Is there still something stuck in that spot? If it is trying to open the tape compartment, you could try helping it along and see if it is just caught. As long as you don't apply too much force, it should open without wrecking anything. Just be aware of what parts are supposed to move before doing this. Let me know how this goes.
  • Benjamin Patri
    Now that it is fixed, please feel free to give me some feedback by rating my solution as I appreciate any that I get.
    Have a Great Day!
    President:
  • 2,712 Answers
TRY THIS: Open the tape door on the bottom. LEAVE IT OPEN. Power off your camcorder and remove the battery. With the battery removed, move the power switch to ON. LEAVING THE POWER ON AND THE TAPE DOOR OPEN, replace the battery. The tape should eject without damage. This works for many other models as well.
Hope that helps!
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson May 20, 2008
    Here is another solution I found:
    If your carriage is not attempting to pop up at all but is stuck in the
    camera and will not move, this post WON'T HELP YOU. If you're like me,
    however, and have a carriage that tries to eject but can't complete the
    cycle, this may help you. First familiarize yourself with the tape
    carriage. Disconnect the battery and the power cord. Turn the unit over
    so that the bottom faces up, and use the eject button to open the door.
    Examine the tape carriage on either end, and you'll notice a couple of
    springs which keep tension on the outside section of the carriage so
    that it will pop out when the catch is released. The spring closest to
    the front of the unit (the lense) is the one which also operates the
    catch for the pop-out mechanism. If you will put pressure just under
    the top of this spring when the carriage mechanism is at the apex of
    its eject cycle (and before it reloads itself because it cannot eject
    the tape), then the carriage catch will release and pop out, exposing
    the tape for removal. If the unit has "eaten" the tape (i.e., the
    transport mechanism has it pinched or wrapped or both, then when you
    release this catch on the carriage the tape will be pulled, crinkled,
    and could be cut or broken. If this tape is full of important memories,
    you might let the tech get it out himself. Also, more damage to the
    tape will occur if, after getting the carriage to pop out, you try to
    pull the tape out of the carriage after it has opened, if in fact the
    transport mechanism is still hanging onto it. Now close the tape door
    and turn the unit off. Plug the unit in or connect the battery, turn it
    back on, turn it over (bottom's up) and open the tape door. Once the
    tape carriage reaches the apex of its eject cycle, put pressure on the
    top of the spring (the spring end closest to the physical bottom of the
    unit, not the "spatial" bottom since the unit is upside down). You
    should feel the carriage catch slip out of its latching mechanism and
    the door should pop out. If either of these springs are missing or
    broken, the carriage will probably not eject even after releasing the
    catch. If the carriage is not sliding downward (or when the unit is
    upside down, upward) from the bottom of the unit in an attempt to
    eject, then the procedure for extracting the tape is much more involved
    and requires dissasembly of the unit in order to get it out.
  • Swilin Sampson
    Looks like the tape head cover (the plastic lid-like-thing that protects the magnetic tape underneath) is engaged. Try this..at the side of the cassette, on the top (usually right) side, you should see a small plastic button/tab that releases this cover. Try pressing this button down and gently extract the tape with the other hand. Off course, you will have to remove the outer panel on the camera first to achieve this..
  • Swilin Sampson
    Well, glad that worked! Now you just have to decide which of the solutions helped you most and assign a fixya rating or an "accept" rating :)
    Sergeant:
    Champion:
  • 347 Answers
Hi Ihoover, i dont know what GTM (global time zone) are you, so, why dont you check this link out and see if they (sony) can provide you a free online chat with them.
Try that, if it dosent help at all, let me know and i will further help you.
Good luck and thank you for using this service
Dahaka
http://esupport.sony.com/perl/support-contacts.pl?template=EN
    Genius:
  • 3,422 Answers
Goodluck..
Play back pre recorded HI8 tapes on my TRV130?
The Sony DCR-TRV130 is a D8 digital camcorder which is not compatible with Hi8 camcorders.
You need to have an Hi8 camcorder or DCR-TRV103 or similar camcorders that backward compatible with Hi8 camcorders.
Dec 31, 2014 | Sony Handycam DCR-TRV130 Digital Camcorder
No sound on tape playback.
Are you using the sony software to download and convert the video?
Sep 08, 2008 | Sony Handycam CCD-TRV37 Camcorder
Tape stuck
DIY remove Hi8 tape stuck camcorder Check this link as it might help out to remove the cassette.
Jan 23, 2014 | Sony Handycam DCR-TRV30 Mini DV Digital...
Sony ccd trv43 doesn't play hi8 after placing an old video 8 tape
Try to clean video head with cleaning cassette, if same position than video head need to be change
Mar 28, 2010 | Sony Handycam CCD-TRV43 Camcorder
Sony handycam video cassette
To the best of my knowledge 8mm VTR's have not been available for some time now. On the other hand there are plenty of Hi8 cameras and players available after market. eBay is a great source. Keep in mind that Hi8 cameras and decks will also play standard 8mm video tapes.
There are also many video tape transfer services that will transfer your 8mm tapes to DVD or other formats of your choice. Just Google "videotape transfer service"
Aug 28, 2009 | Sony Hi8 CCD-TRV138 Camcorder
Hi8 Tape Will Eject but will not forward/record/rewind,
a problem with an electro mechanical mode-select switch there could be a timing problem arised by mechanical problems on contacts inside (an old video recorder problem between the seventies and nineties ) all equipments where tapes or cassettes are used.
A service manual for timing should be neccesary
Sony CCD TRV16 Hi8 Handycam Camcorder Service Manual Page 13
Apr 01, 2017 | Sony Hi8 Hi-8 Tape
Hi8 Playback Problem
Clean the tape heads and see if that makes a difference.  If that doesn't work, it could be the tape motor is going out.  Thats typical behavior when that happens.
Oct 07, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Imovie imports Hi8 tape but not plain 8 tapes
What it is, is the standard 8mm tapes are not digital, and therefore won't import into imovie, unless you have the 8mm to Hi8 option enabled in playback mode, by setting it in the menu, under playback settings.
Dec 29, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Sony Hi8 Hi-8 Tape Logo
392 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
