Have NEC RIH-2667 Inverter Split system.I set to Heating mode,set temp to 25 degrees.The compressor light comes on.The run light flashes for about 30 seconds.Then the vent opens,the fan comes on and starts blowing out heat.Within 5-10 mins the temp on split displays starts going up.when it gets to 26-27 the run light flashs,fan stops,no heat coming out.The temp on system keeps going up to 30 degrees.it takes approx 40-60 mins to come down to 25ish the will come on again and repeat.I have an independent temp gauge in room which in this time period doesnt go above 25 degrees and goes down to 23 degrees while split is coming down in temp display.Is this normal as room does not keep warm like other split in another room keeps warm all the time.Thanx in advanced
  • ellecee May 28, 2008
    I have the same problem!!
    When I turn it on, in heating mode, it will open and work for about five minutes. My display will rise to 32 degrees (which blatantly is NOT the temp in the room) and there will be no air coming from the unit at all. Would love to get a solution - it's getting really cold here!!!
  • kbrion Aug 07, 2008
    I have a NEC Split system also. It will not stay unless I set the temperature to 27 degrees or above. If I leave it on 26 it will run for 1 minute, turn off for 10 mins, then run for 1 min etc.
    The room temperature is freezing and clearly not above 26 (more like 17 or 18).
rayname
  • 70 Answers
SOURCE: NEC split A/C is not cooling for me
if your outside and inide units are running and your tstat has fresh batteries and your air filter is fresh then I will need more info to help solve
Posted on Jan 05, 2009
BIKER T
  • 909 Answers
SOURCE: Blueway air conditioner not fully cooling
Check the radiator for dirt, and check if the radiator fan is functioning. Do you notice any wetness or ice build up on the outside copper pipes. If so, suggest calling a refrig. tech. to add gas. The gas used is R22 on most aircons.
Posted on Feb 02, 2009
SOURCE: not working probly two flashs then pause
The two flashes are telling you what's wrong with the unit. Take the cover off of the unit inside(evaporator) and there should be a guide on the panel with the wiring diagram. On this diagram there should also be a solution to what each blink means. One blink means this, two blinks mean that, etc... Hope this is helpful.
Posted on Mar 14, 2009
bobicehouse
  • 1524 Answers
SOURCE: NEC RIH 2667
Circuit board
Posted on Apr 23, 2009
heatman101
  • 43501 Answers
SOURCE: Daikin Inverter Split system turns
There are quite a few things that can cause the symptom you are describing there...
The most common would be for you to have a refrigerant leak in the system that is causing the outdoor unit not to run, but the indoor unit still will run...
Often there will be a diagnostic LED on the outdoor unit that will help with troubleshooting...
Of course also a good thing to try is to remove all power to the unit indoor and outdoor...and then reapply the power and see what happens...this may correct the fault...
here is a tip that also will give you some things to check....
Feel free to comment back with any more questions...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Feb 05, 2011
Blue Star 1.5 ton 5 star inverter split AC remote "TEMP" button seems not functioning. does any one help me? how to check this function as always remote is showing set temperature.
does that on mine as well
the temp is what is on the inside wall unit when turned on the remote reads 25 and the inside unit reads 30 but eventually comes down to 25
Apr 14, 2017 | Star Heating & Cooling
I dont want all those setting i want to set to a temp and the a c starts and cools to that temp and shut down how do i do that
on the remote , switch the machine on and then press the temp button to the temp that you want
remember the lower the setting the longer the machine will run and the more often it will cycle
recommended setting for maximum power saving is 25 Degrees and i have been running an ac at that for 15 years
I have had to replace it with a inverter system and have found that the system removes all the humidity from the room and so a setting of 27 degrees is more pleasant
I have noticed that although inverters run the compressor all the time (it is the load that varies) there have been times when the outside temperature fell below the set temperature and the compressor actually stopped until the room exceeded the set temperature.
so turn off all the settings not needed and simply switch on the machine and set the temp desired by the remote.
May 08, 2015 | Heating & Cooling
How to heating. it's always cooling
Keep heat mode and temp setting+5 degree than your room temp.Still no heat check power to heating element. No power replace heating temp senor. If it's with RV, check power to RV and also warm in suction pipe(higher size pipeline near compressor).
Jan 27, 2011 | LG LS-K2430HL Heat Cool Mini Split Air...
I have a brand new york inverter air conditioner that does not want to cool!
To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode. First, check your compressor is working?
Dec 29, 2010 | Heating & Cooling
I have a westinghouse window unit and I think it has heat strips for the heat. How do I tell if it is a true heat pump or if it has heat strips and how do I get to the Heat strips in the unit to check.
If it is a heat pump, the compressor will be running both in cool mode and in normal heat mode.
Confirm the current indoor temperature. Turn the thermostat up one degree at a time until it comes on. This will typically be 1 to 4 degrees increase. As soon as it comes on stop increasing the temp.
If the compressor is running, it is a heat pump.
Check the temperature coming our of the vents at that time. You should have 30 to 60 degrees increase from the air temp going into the unit and the conditioned air temp coming out.
Then turn the T-stat up another 10 degrees. If the temp coming out of the vents increases by 20 degrees or more. the strips are on.
The strips operate in three situations.
1) the system is set to emergency heat
2) The heat pump cannot keep up with the demand for heat. (because its too cold outside, the desired temp setting is greater than 4 to 8 degrees above the room temp, or the HP is malfunctioning.)
3) The HP is in defrost mode
You could also take the panels off the unit and look for a reversing valve, but unless you know what you are looking for you will not recognise it.
Oct 12, 2009 | Heating & Cooling
I have an electrolux split system airconditioner model no.EJE24HRA it has not been used for months but the display panel is suddenly flashing Auto and if I do turn it on it suddenly switches itself off...
there is a auto switch button inside the indoor unit just above or on the side of digital display but you must open front panel to get access to it when you do, press that button which says auto once to cancell it from coming on than set your mode on the remote to heating then press start or on button on remote. be sure to set temp to atleast 30 degree before starting it
Sep 27, 2009 | Electrolux E23CS75SS Air Conditioner
Heating & Cooling Logo
218 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
