After hooking up wireless router model #WRT54G2, all I get is a error code that my either net cable is unplugged when it is connected per installation CD (checked it numerous times) Is my cable defective?
  • CJ1952 May 23, 2008
    Only stated the obvious, and to no avail. Must be a bad cable.
    Thanks for trying.
  • 3,940 Answers
The problem is one of three things. The order of replacement is as follows:
1. Bad Cable
2. Bad Network jack connection
3. Bad router
When items are functioning properly you will have connect LEDs on the network card and the router. Also ensure that you TCP/IP setting are set to obtain an IP address automatically
Posted on May 20, 2008
What wires go where to hook up my linksy srx 200 router to my pc so I can view my laptop
In order for you to connect your desktop computer to this router you need to go get a CAT5 cable also called a Ethernet cable.
Jun 27, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I have 2 desk top computers hooked up to one internet source and they are hooked up to a box which my old linksys router was hooked to. I now have a lynksys wireless router G. i unplugged the internet...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 11, 2010 | Linksys WRT54G2 Wireless Router
Problems with WRT54G2 and DNS
If there is only zero on the ip add, sub mask etc then it would never work.Make sure your router is connected to a modem and that the latter can be hooked directly to a pc with cable and test if there is an internet connection. If there is a connection go back to your pc and connect to your wireless.Then go to start>cmd, a black screen would appear and type the following : ipconfig /iprenew .Then afterward type ipconfig and see if the zeros' you mentioned earlier changes to a value to the format of x.x.x.x .This should solve your problem.
Feb 02, 2010 | Linksys WRT54G2 Wireless Router
How to find security code for linksys WRT54G2 to
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Jan 28, 2010 | Linksys WRT54G2 Wireless Router
I have a WRT54G2 Wireless router. Works okay with
yes mke sure wep is correct code. make sure you home security level is the same as your laptop. have tried hooking up your laptop to the home with a cat 5 cable. we had to do this with 2 dell vista laptops. then disconnect lan and we hooked up wirless just fine. something in vista firewall settings.
Dec 31, 2009 | Linksys WRT54G2 Wireless Router
I have a wireless G Broadband Router Model no#WRT54G2,I am having trouble knowing which cords do I hook-up to my Cable modem and computer?
You will need 2 ethernet cables.
modem will connect to the router on the Internet port.
The computer will be connected to the POrt 1 or 2 or 3 or 4 on the router.
Click Here for step by step solution
Nov 02, 2009 | Computers & Internet
321 error
try this power of both pc and router , unplug router power on pc then power on router see if it then picks up the isp, if not just simply unpup router and plug it back in while pc is running hope this helps!!!! good luck
Mar 23, 2009 | Linksys WRT54G2 Wireless Router
Cannot connect to the internet with my laptop
To connect to the router wirelessly using a Windows XP, right click on the wireless network connection icon on the lower right corner of the screen and choose view available wireless networks. Select your existing network and click on the connect button. If you are using Vista, go to network and sharing center of your control panel then select connect to a network. If you still having problems, please provide details of the problem like your Internet service provider and if there are already other computers online with your WRT54G2.
Jul 11, 2008 | Linksys Ultra RangePlus Wireless Routr...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
