Question about Fisher and Paykel GWL11 Top Load Washer
GWL11 burnt smell
My four year old GWL11 washer stopped working today. When I lifted the lid,it smelled like something was burnt.It will not power on at all now. Any ideas?
Thanks,
Steve
  • 3 Answers
There are 2 electronic modules in these machines, which often suffer voltage surges/shorts and cook. They can be repaired, but not cheaply. This happened to me a few times before I gave up on F & P washers, because they are basically ****.
Posted on May 29, 2008
  • 868 Answers
Motor needs to be checked
Posted on May 26, 2008
Sewer smell in clothes
The tub is probably pretty dirty. Try cleaning the washer with CLR.
Visit this information:
http://www.ehow.com/info_8053120_clr-clean-washing-machines.html
Mar 19, 2014 | Fisher and Paykel GWL11 Top Load Washer
Spin cycle not removing all water - seems like it used to do a much better job. Used to achieve maximum spin speed faster than it does now and there is also a low growling noise at the beginning of the...
This is a belt drive machine, it takes more power to spin than to wash if the belt is worn it could spin slower, do you smell any belt russery burnt smell?
Sep 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
Burnt smell and stops runnin mid cycle?
Hi dear.According to your saying,I can say your washers pump out of order.You need to replace the pump.However if you can give me more info I can be more specific,like:when washer stops it does give error code.From left to right please let me know which of the "washprogress lights"light ups.(1st one-3rd one & so on.)Then I can help you more well then guess work.I hope that helps.Thanks.
Aug 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 90 Series, 10 years old; Dryer was making funny noise and stopped in the middle of a cycle. There was a burnt smell when it stopped. Cannot turn drum manually either. What are possibilities?
OF COURSE SOMETHING BURNT INSIDE THE SYSTEM. YOUR MOTOR MIGHT BE BURNT. 90 SERIES, YOU MUST HAVE THE LINT FILTER ON TOP CORRECT? TAKE FILTER OUT, UNSCREWS THE TWO SCREWS, PULL TOP PANEL TOWARDS YOU AND LIFT UP. DISCONNECT LID SWITCH CONNECTOR, UNSCREW TWO SCREWS HOLDING FRONT PANEL ON, REMOVE FRONT PANEL, TAKE DRUM OUT AND CHECK THE UNIT. GOOD LUCK
TIMOTHY DO 714-334-1998
Aug 04, 2010 | Kenmore Dryers
Washer fills up, but nothing else
Usually the lid switch will let it fill, but do nothing else. Sometimes if you just drop the lid hard the switch will make and it will go through its cycle. If there is the smell of something burnt, it may well be the lid switch.Unplug the machine from outlet, then, lift the entire top of the machine, you will be able to see that switch. Pull the two wires off of the switch and with an Ohm meter, check your switch. It should register open when lid is open, closed when lid is closed. If you are not getting these readings, remove the switch--mark your wires! and replace. You should be able to purchase new switch where you purchased your machine
Jan 10, 2010 | Washing Machines
Maytag washer top load
hi thanks for the question i think you could have a problem with your tub bearing or you could have a piece of clothing caught between the tank and tub remove the front lift up the top remove the plastic top and look you will see if you have something caught in the space between those two pieces thanks the appliance doc
Sep 24, 2008 | Maytag PAV2300 Top Load Washer
Whirlpool ultimate care 2
Peace,
ngafm at your service,
Things wear out! So is life!
Sounds like the belt wore and slipped and broke!
Is there any power to the washer?
How old is the washer?Sounds old.
Only a trained laundry tech can make the electronic diagnoses.
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
I
Sep 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
No Power to washing machine
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Jul 13, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Crosley washing machine cw6000
I WOULD RECKEN WHAT YOU HEARD WAS THE BEARINGS IN THE MOTOR GOING AND WHEN YOU TURNED IT ON AGAIN IT SEIZED THATS WHY THERE WAS A BURNING SMELL JUST REPLACE MOTOR
Apr 04, 2008 | Hotpoint Aquarius WD63 Front Load...
Burnt rubber smell
the belt is broken. the machine wont spin or agitate with a broken belt. set the timer to spin and the water should still drain. but not spin. belts are very cheap but replacing on could be tricky if you dont know what your doing
Jan 24, 2007 | Maytag Performa PAV2200
Fisher and Paykel GWL11 Top Load Washer Logo
254 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
