Question about LG Dishwashers
I have LG dishwasher for 2 years now. Working perfectly until one day one glass gets broken during washing cycle. Immideatly we get EO error. We check possible reason of error in the manual then decided to try to fix ourself. We open bottom cover and drain outcoming part. Immideatly we discover a piece of glass that was preventing a small plastic piece to rotate. We remove that piece of glass. Put back covers and machine. We connected it back to outlets and run it. All was working again !!! This is advise for everybody do not call service before checking the same by yourself ! As I read in internet in general service is qiute expensive and offten they are saying - you need to replace some part etc.... and this is very expensive. Try to do steps that I wrote and hopefully you are saved.....
In order to fix problem we disconnected dishwasher, put it on one of side, opened bottom cover - the one that is outside of dishwasher. We find out the part that is
connected to the drain horse. We take of 3 screw and open that part too. We discover
few small peices of glass that were preventing to rotate one plastic part of dishwasher. We removed that pieces of glass. Put all back and connected dishwasher. All was working fine. I am suggesting to everybidy try these steps before calling for any service.
Posted on May 20, 2008
Hobart glass wash machine amx-gh continue washing does not advance to the rinse cycle with no error code
only a suggestion is it heating up what i remember it want move on until it heats up to it's working temperature, good luck
Sep 22, 2016 | Hobart Dishwashers
I ned help finding a manual for a bosch dishwasher model sgs4012GB
i got the perfect answer. go to thermador.com they can order this for you. bosch, thermador and gaggenau is the same company. if this helps you post a 4 thumbs up post
Feb 21, 2010 | Bosch 24 in. SGS4072 Free-standing...
The code EO comes on after the thrid cycle on our Hobart glass washer what should I do
E0 STANDS FOR NO WATER @SUMP PROBE DURING 3 CONC. CYCLES. MY FIRST GUESS WOULD BE THERE IS SOMETHING STUCK IN YOUR DRAIN VALVE ALLOWING ALL THE WATER TO GET PUMPED OUT INSTEAD OF WASHING AND STAYING IN THE TANK. DONT FORGET TO VOTE
Oct 23, 2009 | Hobart LXiGC Dishwasher
Have a 2+year old LG LDF6810ST dishwasher that shows no error codes but is not cleaning like it used to. Have city water, do not leave excess food on dishes when loading, am only using powder after...
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Aug 12, 2009 | LG LDF6810ST Stainless Steel Built-in...
Motor just hums during the wash cycle. Put it in
OK, that piece of glass may have jammed the wash impeller. this will destroy the motor windings. you will need to gain access to the circulation motor asap.the impeller is attached to the motor that is housed within the pump casing(upper). try to manually move the impeller. if its stuck, try ot remove the obstruction.
It is possible that, the motor is already damaged to the point of no return. in this case, replace the circulation motor. your drain pump should be ran by a totally separate motor(wax).
**NOTE
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Jun 09, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher will not go into wash cycle.
On the LG LDF6810 dishwasher, the best you can do is remove the bottom spray arm and then the 10 phillips screws that hold the filter down.
Pull the filter out and clean it as best you can.
Inspect the sump area beneath where the filter was. Be careful of broken glass and remove all debris. Use a flashlight and look into every little spot down there. Reassemble the dishwasher and operate your DW.
If you still have problems, I recommend a service call. Check your manual to confirm but most LG dishwashers have a 1 year parts & labor plus a 2 year parts only. Have your proof of purchase ready.
Apr 02, 2009 | LG LDF6810ST Stainless Steel Built-in...
Not all of the soap dissolving, some left in dispenser and bottom
Kitchenaid lists 130 dishwashers with this model. Need the rest of the number
KUDSO1DLxxxx
Back in the day, when I worked on K Dishwashers, the drain valve was the problem typically.
It would get a piece of glass, from broken glass or other item, or a toothpick, whatever stuck in the drain valve. It would not completely close. During the wash cycle, water would be trickling down the drain and by the time the soap dispenser opens, the water would be gone or nearly gone.
Check this. When you hear the dispenser snap open, stop the dishwasher and open the door.
If you have little or no water, you are losing the water during the wash cycle.
Let me know.
Gary
Nov 22, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
LG Dishwasher Model LD-14AW3
I have had this dishwasher about 4 years, it has work beautifully, then one day there just wasn't any power going to it. Have tried different power points and no change. Looked for a fuse, was unable to find one. The power cord coming into the machine is undamaged. Any suggestions.
Mar 28, 2008 | LG 24 in. LDF 7811 Stainless Steel...
ERROR CODE
Aug 27, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
139 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
