Question about RCA D52W19 52" Rear Projection Television
Replacing color wheel on RCA M50Wh185 - RCA D52W19 52" Rear Projection Television
  • 3 Answers
I have posted photos of replacing my RCA DLP color wheel on snapfish, here is the link.
The key is not to go through the back, but through the front by dropping the screen. After removing the screws that hold the screen to the chassis, it pivots out allowing you to reach in, remove the light shrouds and then by unscrewing four color wheel screws and disconnecting two connector cables to pull the color wheel out.
http://www1.snapfish.com/share/p=991241224865368552/l=438844205/g=6447808/otsc=SYE/otsi=SALB
Posted on Oct 26, 2008
  • RCA Master
  • 8,617 Answers
What are you needing to know about replacing the color wheel?
Posted on May 20, 2008
MY RCA SCENIUM M50WH185 AFTER TURNING IT ON IT RUNS FOR 10 MINS THEN LOOSES PICTURE &VOLUME AND WILL NOT TURN BACK ON- GOT TO UNPLUG IT WAITE 4 A WHILE THEN PLUG IT IN AND IT WILL COME ON AT SOME TIMES...
your power supply unit is going bad you dont have much longer before it goes your volume buttons picture light. screen all run through it. go to vancebaldwinelectronics.com to replace it.
Jan 08, 2011 | RCA M50WH185 Television
Power switch lights up,flashes 5 times,goes out,nothing happens,no picture,no sound
There are quite a few possibilities with the 5 blinking lights:
  • Possibly a bad power supply board (check the lamp first, then troubleshoot further)
  • The lamp is faulty
  • The ballast is weak and unable to ignite the lamp
  • The ballast is faulty
  • The color wheel is not responding
  • The light engine is not responding
  • The lamp is not seated properly, or has not made a connection with the ballast.
Are there any other indications?
Feb 04, 2010 | RCA M50WH185 Television
Need a color wheel for RCA Scenium HD50LPW165 50 in Rear-
that color wheel has been discontinued by RCA. Its the 267888 color wheel. You can get your color wheel rebuilt at the following link under color wheels.
http://servicemanuals.vstore.ca/
Oct 16, 2009 | RCA Scenium D40W20 40" Rear Projection...
RCA HD50LPW42. Sound so loud it sounds like a jet engine coming from TV (very loud whining sound). I assume this is my color-wheel, but I'm not sure.Turns off when TV turns off.
You need a replacement color wheel or have yours rebuilt since the RCA color wheels are on nationwide back order. You can get your wheel rebuilt at the following link
Sep 08, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
RCA Scenium HD50LPW166XY1 DLP Projection HDTV ''scream''
RCA has discontinued the color wheel for your model and its on nationwide back order, so you cant buy the replacement. You can get your color wheel rebuilt at the following link and the rebuilt color wheels are fully guaranteed.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-color-wheel-267888-rebuild-option/cName/color-wheels
Jun 14, 2009 | Televison & Video
Want to know if color wheel can be repaired?
Unfortunately, you can't replace just the bearing. You would have to replace the complete color wheel. Here's a link for a major parts distributor so you can get an idea on priceing:
RCA HD44LPW62 Replacement Part Color Wheel
Jan 23, 2009 | RCA HD61LPW165 61" Projection HDTV
Does any one make a replacement color wheel for my rca #hd50lpw62ayx2 projection tv? And if so, replacement procedure to replace. Thanks
You can find a replacement color wheel for a model # HD50LPW62AYX2 at this following link:
RCA HD50LPW62AYX2 Replacement Part Color Wheel
I'm not sure about how to correctly replace the part. Hopefully a tech whose dealt with this model will post an installation guide.
Dec 15, 2008 | RCA HD61LPW165 61" Projection HDTV
RCA HD50LPW62AYX2 50" - color wheel replacement procedure
REMOVE ALL SCREWS AROUND SCREEN AND REMOVE SCREEN. REMOVE 2 SCREWS HOLDING PLASTIC PIECE IN MIDDLE. GENTLY SLIDE OFF CIRCUIT BOARD (JUST GLUED FROM THE BACK). REMOVE PLASTIC PIECE TO EXPOSE OPTICAL CHASSIS. REMOVE THE LAST REMAINING SCREW FOR LIGHT FIXTURE. REMOVE 3 SCREWS HOLDNIN COLOR WHEEL. REMOVE RIBBON PLUGS AND REERSE THE PROCESS TO INSTALL. JERRY.(ROCKMANJV@COX.NET. LET ME KNOW HOW HAT GOES. i'M WAITING ON THE PART RIGHT NOW. WHERE DID YOU FIND YOUR PART? THEY ALL TELL ME THE PART IS ON BACKORDER. SEE YA!
Oct 23, 2008 | RCA HD61LPW165 61" Projection HDTV
How to replace the color wheel on a RCA DLP
RCA DLP color wheel replacment is most efficiently done from the behind the screen, not the back panels where the guts of the DLP are located.
From there you do not need to remove anything but the color wheel and disconnect the two wires.
If you want to see pictures, email me and I can send you pictures. email: graphguy@gmail.com
Jan 18, 2008 | RCA HD61LPW165 61" Projection HDTV
RCA D52W19 52" Rear Projection Television Logo
765 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
