Question about Maytag Neptune MAH5500B Front Load Washer
Follow up on Neptune Problem
Specifically, the problem is itermittent. When it occurs it is at 7 to 8 minutes left in the cycle. No rinse spin and no finally spin. I think it does spin or at least empty during the wash cycle. I have been able to eventually get the washer do do correctly. So now I don't know what I should do!!!
  • 868 Answers
You need to replace 2 parts here.The control board(located in timer panel)2.replace the wax motor.
Posted on May 24, 2008
My neptune washer will start and run about half a cycle and it acts like it gets stuck and on one cycle and never shuts off. I put a load of clothes in before I went to bed and next morning the machine...
What does half a cycle mean are you in Wash cycle, Spin Cycle? What does the Cycle Status LED indicate?
If you think the wash load is in a spin cycle of the wash cycle or rinse cycle place the machine in Spin Only cycle and see if it will complete.
Waht are your DIY skills? Do you want to try the repair/fix?.............Rich
Oct 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
OK during wash and rinse cycle but suddenly became very noisy during high speed spin cycle
If noise occurs only during spinning cycle, then the 2 bearings and seal need to be replaced.
May 23, 2010 | Maytag Neptune Washer
Neptune Washer Spin Cycle
If your FAV6800A or FAV9800A wash tub is banging around in Spin Cycle of the Wash Cycle and your Control Board signals a dC or uC error code to the console I feel you have a Clutch malfunction. I feel the TDS is working as designed with the unblance error code shut down.
See my Clutch Fix post for more info related to dC and uC unbalance errors with the FAV6800A and FAV9800A TL’s and the repair action…….Rich
May 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer will spin while in rinse mode, but does not
this could be a main control board problem.how ever i would check the drain pump for any kind of foregin object that may be causing the drain but to stop functioning.last resort bad drain pump
Sep 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire gallery front load won't spin
Does the washer spin after the wash cycle? It sounds like the door switch. This is a common problem with frigidaires. 90% of the time a door switch fixes it.
Jul 01, 2009 | Frigidaire Washing Machines
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code ''oe'',
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual, it may not be there, they want a tech to come by to make more $). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum) Of course some direct the hose into sink, fine. Snaking out your standpipe would be good too.
Rate me nice or not at all. Happy spinning! Nice to watch the machine spin, not your head!
Mar 04, 2009 | Washing Machines
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
Mar 02, 2009 | Maytag Neptune MAH9700 Front Load Washer
Strange growling sounds on rinse and spin cycle
I would check the motor control board located near the floor on the right side for burnt components. The motor is a 3 phase unit and if one of the phases are working the motor will growl and won't be able to supply the proper torque.
See www.neptunehelp.com for disassembly photos and for more info on the faulty door latch wax motor.
Jan 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah8700. Will spin at the end of quick rinse cycle but not on any other cycle. Error code I get is SUSP. Washer does drain out.
Hi
My name is Gloria, my neptune washer will not spin on the last spin cycle of any of the washing cycle. A code of uC comes up.
Aug 08, 2008 | Maytag Washing Machines
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
77 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
